AF ratio, can someone explain
.95is fairly rich but it depends on your exhaust gas temperature.
Non-wideband O2 sensors (what our cars have) are not designed to be accurate at anything other than stoich. They can be used for a good ballpark idea of how rich/lean you're running at WOT but that's about it. .930mv is generally just a little on the rich side. .830mv is generally just a little on the lean side. .870-.910 is [i]generally]/i] about where you want it. The thing to remember is that O2 sensors vary from car to car and what fuel/air mixture makes best power varies from setup to setup.
