Whats the best performing stage II LS6 heads and cam available now!
Out of curosity,if $ was not an option and you wanted to get the best performing heads and cam package available on the market whose Ls6 heads would you get and what cam would you run on a A4 LS1 (naturally aspirated application only)? This heads and cam would be coupled with long tube headers, zo6 intake and all other basic important bolt ons. Obvisiously passing emissions is not a concern and what would make the biggest power on the dyno but more importantly, what heads and cam combo would most likely put a LS1 A4 into the 10s on stock bottom end and cubes in your opinion or get you closest to the 10s as i realize the 10s on stock Ls1 cubes naturally aspirated is one TALL ORDER no doubt.
Thanks,
MTI 422 Z07 Roadster
Thanks,
Stang Killer:
I assume you meant MTI heads vs MIT? I just want to make sure i'm not missing something here.
MTI 422 Rdster
MTI 422 Rdster
ARE, MTI, GTP and others all have cars in the tens with A4 and HCI setups.
Take your pic <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chris
Chris
Is this post just out of curiosity, or are you changing your setup. If you're changing your setup, why? And stock bottom end...???
No flame...just wanted to understand the motives.
MMS LS1 heads/cam setup in the 10s here. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
FASST:
Nooooooooooo, no way am i changing my set up, i am actually doing a little research for a fellow LS1 gearhead colleague and just love talkig LS1 HORSEPOWER BABY!
Thanks,
Thanks,
If money is not an option then C5R heads. Other than that pretty much each company has a car running in the 10s with their heads.
Cartek has a few 6 speed corvette's in the 10's with just heads and cam LS6 heads and a custom cam. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
