OCTANE----PRE-IGNITION
lets suppose im driving home in my above average WS6 when behold, the heat from my header fries only one of my spark plug wires (assume no spark). the other 7 cylinders are pumping like champs. meanwhile, the cylinder with no spark is still being pumped full of air and fuel. what happens here? does the mixture combust completely due to the pressure of the piston and heat from the head and adjacent cylinders? does it combust only partially, leaving your hometown full of crap? or does it not combust at all, and exit through the exhaust valve? assume normal atmospheric conditions standard ls1 or lt1 CR, and premium fuel ( i dunno...91?)
i say the mixture combusts partially (not clean).
my friend says in his words "nothing will happen. fuel will just come out."
so...i know compression ratio, air density, octane, temperature, and a couple other things determine the rate of burn. make a few assumptions.
who's right?
<small>[ November 04, 2002, 11:18 PM: Message edited by: Cobalt ]</small>
Just a guess!
<small>[ November 04, 2002, 11:37 PM: Message edited by: 96-speed ]</small>
<strong>ALERT: 96-speed is the friend.
cheater.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Haha
I am no expert by any means. But assuming there is 0 and I stress 0 spark in the chamber along with the rest of your conditions I would say the A/F charge is just along for the ride through the head and out the exhaust wothout combusting. You would probably throw a misfire code as well. If there really was no spark and you had ignition in that cylinder that means problems like pre-gnition or hot spots, bad gas, etc.
Most of my experiences with something similiar to this though have almost always had a partial spark making its way to the plug...and giving partial combustion of some type.
<strong>does anyone know the amount of CR and heat to combust 93 octane gas, with no spark?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its definately not enough to cause combustion without ignition. Put your hand on the header primary after a few minutes and you can see how it stays cool.
With no spark at all, raw gas will be pumped out of the cylinder into the exhaust system washing oil off the rings and cylinders as it goes. You would need diesel type compression (16:1 or higher) to burn the fuel mixture with no spark in a gas motor. At such high compression, the gas mixture will not 'burn' as it should, but will simply EXPLODE, and the results will not be pretty. In addition, you'll throw some sort of SES code from such things as spark knock, O2 sensor, etc.....
i am curious though NC Guy, where did you come up with a 16:1 CR in order for the fuel to ignite with no spark? not saying your wrong, so please dont take it that way. it just seems like an assumption? <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
theres got to be a static CR that is needed in order to ignite 93 octane fuel. right?
When there is no spark you have a dead hole, you could touch the header tube when you are done with it, it will be cold. The air/fuel with head right to the exhaust and prolly throw a code because you will be rich and the computer can't fix it.
Gas in an engine never explodes, it burns. Explosions by definition are at a high rate of speed like 2000mph rather than the 6-7mph of BURN that happens in a engine. The pre-ignion, or knock is caused when the charge starts to burn some place else and the two flame fronts meet and "knock" into each other. A octane rating is the ability for it to resist doing this without the introduction of a spark into the system.
The dynamic compression ratio is more important to induce a burn on gas when it is ignited, but I don't really think there is a minimum, but yes it will be more inefficent.
I don't want to support another forum, especially one I don't sponsor, but the CamaroZ28 Advanced Tech Forum has this same question in it right now and it gets even more indepth.
Bret
<small>[ November 06, 2002, 12:01 AM: Message edited by: SStrokerAce ]</small>
Charlie.
