Roll master double rollor timing chain and ASP pully.Does it fit?
Old Nov 8, 2002 | 11:31 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Roll master double rollor timing chain and ASP pully.Does it fit?
I was told that the pulley might have to be machined.Is this true?Anyone running this setup?
Old Nov 8, 2002 | 11:46 PM
07BlueDevilZ06's Avatar
Default Re: Roll master double rollor timing chain and ASP pully.Does it fit?
i have both on my car with out any problems
george
Old Nov 9, 2002 | 08:03 AM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2002nhraformula:
<strong>i have both on my car with out any problems
george</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Anyone else??
Old Nov 9, 2002 | 09:52 PM
Scalpel's Avatar
The ASP pulley + Rollmaster combo needs adjustments on the C5, though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 9, 2002 | 10:15 PM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NastyC5:
<strong>The ASP pulley + Rollmaster combo needs adjustments on the C5, though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What kind of adjustments???
Old Nov 9, 2002 | 10:47 PM
Scalpel's Avatar
You have to machine the ASP pulley to get it to seat all the way.
Old Nov 9, 2002 | 11:13 PM
Brownie's Avatar
There was a post about this a little while ago and in that post it was said that the ASP pulley has to be machined. There is even a picture.
Speed Inc. installed mine and they told the guy who posted that they have to machine the pulley for clearance.
Mike
Old Nov 10, 2002 | 02:06 AM
QuickSilverTA's Avatar
Fits fine on F-bodys
Old Nov 10, 2002 | 02:20 AM
RTCamaroSS's Avatar
Yeah, i have the rollmaster and asp pulley on my 99 SS, no problems... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 10, 2002 | 06:53 AM
StevieZ's Avatar
Is the Rollmastetr double the same chain as SLP sells?
Old Nov 10, 2002 | 10:14 AM
Scalpel's Avatar
Yes, the Rollmaster and SLP are one in the same.
Old Nov 10, 2002 | 11:18 AM
Slammed Vette's Avatar
I had Cartek machine my new pulley to fit.
Old Nov 10, 2002 | 11:31 AM
PurEvl's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slowhawk:
<strong>I was told that the pulley might have to be machined.Is this true?Anyone running this setup?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Issues on a C5 but not on the F-bod, thats what I have heard anyway. Mine goes on in the next two weeks so I will let you know first hand.
Old Nov 10, 2002 | 08:21 PM
LS1 BU's Avatar
I had to have mine machines by Speed Inc.
Old Nov 10, 2002 | 08:27 PM
StevieZ's Avatar
LS1 BU Do you have a Y body or F body?
Old Nov 11, 2002 | 12:16 AM
Buckshot's Avatar
I just installed this combo on my C5 and had to machine the pulley to compensate for the oil pump spacers. I've heard f-bodies don't have this issue.
The spacers on the Roll Master are 3mm thick, pushing the oil pump foward toward the rear of the pulley hub a like amount, so, on the C5, the pulley hub minor outside diameter needs to be machined back 0.125" (1/8") since the oil pump body will interfere with the pulley rotation at the oil seal diameter of the pulley. It's an easy modification any competent machine shop can do. Just make sure they indicate off the diameter so they maintain the pulley's balance when they turn it.
