stage II head question.please help a.s.a.p
Old Nov 14, 2002 | 06:40 PM
9secpacecar's Avatar
Default stage II head question.please help a.s.a.p
what do people think about tbyrne cnc stage II heads with 2.08/1.60 valves.and with my combo: a4 comp cam 224-224/567-567 @114 all bolt on's and hooker lt's 3.73 rear and heavy car?tia.
Old Nov 14, 2002 | 08:21 PM
SStrokerAce's Avatar
Default Re: stage II head question.please help a.s.a.p
Stock displacement?
Not with 2.08's is that going to be easy,
Bret
Old Nov 14, 2002 | 10:13 PM
more input please!!!
Old Nov 14, 2002 | 10:32 PM
VINCE's Avatar
Shorty Director
The valves are huge for a 346ci and will not give you the velocity needed to fully utilize the valves.. I hope I said that right..
Old Nov 14, 2002 | 10:44 PM
BaddMood's Avatar
Depending on how much is taken off the head your piston to valve would be close.A 2.08 valve is very shrouded the bore size is kinda small for that valve it would not flow properly.
Old Nov 15, 2002 | 01:40 AM
i know this isn't the best combo how much will it hurt me? or help over stock heads.
Old Nov 15, 2002 | 08:56 PM
ttt
Old Nov 15, 2002 | 10:24 PM
Brian Tooley Racing's Avatar
Go for either a 2.00 or 2.02 intake and 1.55-1.57 exhaust valves. These idle better and will also make more power on your engine. Vince can vouch for that. Brian @ TEA
Old Nov 17, 2002 | 11:28 AM
99 Black Bird T/A's Avatar
Vince and Brian are on the money.
A 2.08 valve will work best with a bore bigger. A stock 346 won't see much if any benefit from the 2.08 valve.
