MTI X1 vs. TR230 cam???
Old Apr 8, 2007 | 02:48 PM
mead955i's Avatar
Default MTI X1 vs. TR230 cam???
ok. im really stuck between these 2 cams. i see the specs look about the same but i know there are probably some slight differences.
MTI X1 230/227 .591/.571 112 lsa
TR/230 230/224 .575/.563 111lsa
there so close but i see a lot more thunder racing grinds out there. any reason. what can anyone recomend me, which would be better???
looking for a cam only aplication. currently have a 99 C5 vette
short tubes, ls6 intake, 80mm tb, 3.42gears, corsa exhaust...
i am looking to upgrade to long tubes if nessisary...
Old Apr 8, 2007 | 03:24 PM
mead955i's Avatar
ALSO I WAS HOPING SOMEONE COULD SEND ME A SOUND CLIP OF THESE CAMS IF THEY HAVE THEM. PREFERABLY BY E MAIL BECAUSE I CANOT VIEW VIDEOS FROM THIS COMPUTER FOR SOME REASON... THANKS
MEAD955I@IWGI.NET
Old Apr 8, 2007 | 07:28 PM
outkast6991's Avatar
sent you a small clip of my tr 230/224.let me know if you have any ???'s
Old Apr 9, 2007 | 10:36 AM
mead955i's Avatar
thanks outkast. sounds good. is the mti x1 cam have a little more lope? or are thay both about the same? im looking for a tourque monster with some nasty lope! thats why i was looking at the reverse split...
Old Apr 9, 2007 | 11:31 AM
Bad Blu Formula's Avatar
The Tr230 has a bit more lope since its on a lower LSA. As far as torque goes, the TR230 will make 300lb. ft. torque at 2800rpm. I might be a little biased to say go with the TR230.
Old Apr 9, 2007 | 11:42 AM
mead955i's Avatar
it seemed from most the videos ive seen the mti x1 cam seemed really lopey. but thats not the most important thing. low end torque is!!!
any one have a good comparison? or maybe im just looking at the wrong cams.
Old Apr 10, 2007 | 10:09 AM
mead955i's Avatar
well which reverse split cam seems to have the best results with a stock headed car?
Old Apr 10, 2007 | 10:23 AM
5.3LJimmy's Avatar
I had the TR230 in my car w/ stock heads and it was great. Made 116-118 mph in the 1/4 all day long and drove home w/ civility. The cam is now in my brothers car and he is quite attached to it as well. I don't have experience w/ the X1, so I can't compare the 2. My guess is the 111LSA(TR230) would have slightly more low end torque, but the cams are probably really close in overall performance.
Old Apr 10, 2007 | 10:29 AM
Boehlke's Avatar
I've got a dyno of my car with the X1, stock ls1 heads. Sorry about the crappy pic, it's the best I've got at the moment
Old Apr 10, 2007 | 11:13 AM
mead955i's Avatar
the dyno pic didnt show up. maybe its my computer...just a red X
Old Apr 10, 2007 | 11:35 AM
Boehlke's Avatar
OK, try that. This should be working
Old Apr 10, 2007 | 11:36 AM
Boehlke's Avatar
how about now?
Old Apr 10, 2007 | 11:46 AM
PREDATOR-Z's Avatar
X1 would be better with higher compression.
On cam only TR230 is a tough cookie and proven many times.
They are similar cams, if you overlayed them on a same motor they would be very close with TR230 a bit stronger in low to mid.
Old Apr 10, 2007 | 12:37 PM
Azrael's Avatar
Our Camaro did 388/385 with the X1 on stock heads(241), no UD Pulley, and with a 3400/2.2STR TC. I have a video of it idling but we are on vacation in San Diego, so I will not be able to post it until next week.
Old Apr 10, 2007 | 02:05 PM
GTslOw's Avatar
i have a tr230/224 for sale if u are interested only 8000miles on the cam $250 shipped let me know
Old Apr 10, 2007 | 09:46 PM
JaSSon's Avatar
I went X1 cause its closer in duration and has more lift. Its all in what you want.
Old Apr 11, 2007 | 10:07 AM
mead955i's Avatar
SO WHATS THE STORY ON THAT CAM. WHY DID YOU REMOVE IT?
whats included with the cam? any springs? i may be interested
Old Apr 11, 2007 | 10:11 AM
mead955i's Avatar
anyone got more videos of these cams...id love to hear them... e mail them if you can mead955i@iwgi.net
thanks
Old Apr 11, 2007 | 10:19 AM
NOS USER's Avatar
mead955i : I did used the MTI X1 cam ...pull like train & its really a monster with the nitrous.
Thanks.
Old Apr 11, 2007 | 01:46 PM
Function>Form's Avatar
im in the same boat, i have really been looking at these 2 cams.
except i have morgan motorsports stage 3 heads, and a 6-speed, and possibly going to run a 100-shot.
if anyone that has run these with a fairly decent head let me know!
