Best cam for stock heads
Oh yea the car is a M6, and I have no tuning, just a lid and !FRA & vortex muffler. Thanks
Another bargain combo is an LS6 cam & springs --- it will idle better, but you won't pick up as much power.
Comp Cams makes several mild grinds that would work for you. With an M6, you can be a bit more aggressive than an A4, so either he 216/220 or 218/224 grind, on a 114 LSA, would work well. The lift is around .525", perfect for stock heads, and the extra exhaust duration is good for stock headers or shorties. You should have no emissions problems, but might need some A/F tweaking.
I'm very curious about how your cam performs because I just might do the same thing. I won't have enough for LT's for a while, but if I could get the cam, then I could have power and sound. I was leaning to a Hotcam, but feel I would want to change it later when I eventually got headers (in like a year or two). What other mods have been done to your car, besides your sig? Do you have stock programming? I also have an M6, so mine should perform similar to yours. How is the driveability and use of accesories like A/C? Mine is my only car, so I can't sacrifice reliability. Thanks for your help.
Mike
Those seem like pretty good numbers that BadbadZ put up although I'm not familiar with the C1 cam. Thanks again.
