light weight valve train for quick response? 2?'s
Old Dec 16, 2002 | 03:54 PM
finalymodded's Avatar
Default light weight valve train for quick response? 2?'s
1.)Will a lighter valve train provide a faster rev up and then back down? (a quick response inboth directions in the rev). 2.) If so where do i get the lightest valvetrain parts and what are they made of?
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 16, 2002 | 04:29 PM
Zeta's Avatar
Default Re: light weight valve train for quick response? 2?'s
<ahem>
No. Depending on the engine, GM.
See and read. [You are starting on page 2 of the article]
http://www.idavette.net/hib/02ls6/page2.htm
Old Dec 16, 2002 | 10:08 PM
Gary Z's Avatar
Leanne,
I assume that you are wondering about the purpose of lightweight valvetrain parts. A lighter valvetrain will allow your engine to rev higher if your engine is strong enough to rev higher without breaking. The purpose of revving higher is higher power. Lightweight valvetrain components help the valves follow the cam profile at high engine speed. At very rpm valves tend to stay open, a condition called 'valve float'. Lightweight valvetrain components are very expensive - '02 LS6 hollow-stem valves are $40 each. The total cost of 16 LS6 valves, springs, and seals is over $900. Titanium valves are lighter than steel valves but are super expensive. I hope this helps.
-Gary
<small>[ December 17, 2002, 12:37 PM: Message edited by: Gary Z ]</small>
Old Dec 17, 2002 | 01:32 PM
well, where do i get titanium valve train,(all of it),? Assuming that all of the parts being titanium would be MUCH lighter and more strong than the steel, and what kind of price tag would you expect from that? Would you just reccomend getting LS6 heads (02') and just leaving it at that?
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Dec 17, 2002 | 02:13 PM
Gary Z's Avatar
Manley makes titanium valves but you should be aware that titanium valves are only appropriate for all-out racing engines. My car is a daily driver. I wanted the lightweight '02 valves and decided to purchase the complete LS6 head assembly. The complete assembly is significantly cheaper than buying the parts individually. The part number for one LS6 cylinder head with valves and springs is 12564824. They are listed on the GMPP web site. I found the best price at Pace.
<small>[ December 17, 2002, 02:17 PM: Message edited by: Gary Z ]</small>
Old Dec 17, 2002 | 02:30 PM
Thank you so much. Exactly what i wanted to know. I am ordering the fully assembled LS6 heads today.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ December 17, 2002, 02:31 PM: Message edited by: leanne ]</small>
Old Dec 17, 2002 | 03:31 PM
Gary Z's Avatar
Leanne, you should consider whether you want to purchase GM part number 88958622 instead of the stock LS6 heads. For a few hundred extra bucks, this other part includes the '02 lightweight valves but the head is CNC ported and with the right cam could produce much more power. As I said, my choice was the stock LS6 heads but there are other choices.
-Gary
<small>[ December 17, 2002, 03:33 PM: Message edited by: Gary Z ]</small>
Old Dec 17, 2002 | 04:31 PM
i ordered the cnc'ed heads. not alot more so worth it.
Old Dec 17, 2002 | 05:12 PM
Hawkn01's Avatar
Also with the lighter valves you don't need as strong of a spring.
