checked it tr224/afr 205's 59cc
i checked it ptvc with tr 224 with 59cc afr 205's
intake .100
exh .135
with gm mls gaskets and comp pro mag 1.75 rockers
just wanted to post this may help someone someday
but i never got my intake bought from this site.
i will have a fast on the way monday. no more "for sale section " for me
it is like the lotto. some win some lose . i lost.
you can save big or you can lose big.
intake .100
exh .135
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
i could have went with .040 head gaskets i see now but i think my dcr is already getting out there with the 59cc heads. i should be around 11.1-11.2 as is static.
and then with the 114 lsa 224 cam i know i am pushing it.
i am just trying this out. if it don't work i will try a new route.
but i think with the high comp ratio and low duration and good lift it should be a tq monster with a 346 ci with a 150 shot on standby.
time will tell.
time will tell.
You should have ran the .040 gasket, the bump in compression wouldnt have been bad, especially if you run 93 octane. Im at 11.9 on 93 with zero issues. The tighter quench area would have been a good benifit. Either way you have a good combo.
i know. but i was so worried about the ptvc i did not know what to do.
plus the .040 is better to prevent detonation.
maybe being i have to wait for the fast intake to get here i could switch head gaskets . the gm one were only 30 for the pair from summit.
working on my car has become a mind game and my car is winning
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Should be a killer setup! You'll really enjoy the powerband of those awesome heads combined with the TR224. On the jug it should be crazy!!!!
What PTV method did you use? Dial indicator or did you clay it? Off the top of my head I had .200 on both using 63cc 5.3L heads, MLS gasket with my 112+4.
I used clay. i know that seemed tight. but i am running the 1.75 pro mag rockers.
and it is a 2.020/1.6 valve's. i rolled it over a few times i am sure it is right.
I know i check from my stock heads from the gasket surface to the edge of the valve and the afr's are about .040 less. so i don't really have a answer as to why.
just glad i stuck with this cam and no fly cut.
LS1 Tech Administrator
Did you just line up the dots or did you retard it 4 degrees to make it straight up? FYI, the TR 224/224 114LSA comes +4 from Thunder Racing. Lining up the dots does not mean installing it "straight up". Straight up means no advance to the cam (ie 114 intake centerline). To put the TR 224 in straight up would mean you put the cam in at 114 intake centerline which would require you to retard the cam -4 degrees from dot to dot. If that's what you did, that's awesome. I just don't want to confuse anyone out there if they're trying to duplicate your results.
If you put it in dot to dot, let's make it more clear.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
