Head bolt hole in blocks thread size?
Old Apr 14, 2007 | 04:24 PM
Loudmouth LS1's Avatar
Default Head bolt hole in blocks thread size?
One of my buddies ripped the thread out of the block by accident and needs to know what the size is so he can helicoil it, any help is appreciated, thanks!
Old Apr 14, 2007 | 05:00 PM
quick346's Avatar
they are a 11by 2 metric. witch means 11mm dia by 2 threads per mm
good luck
Old Apr 14, 2007 | 05:02 PM
quick346's Avatar
also i doubt a helicoil will hold that much tq. i don't know how you would get it in but i could make you a peice of tool steel with the right thread I/d and with what ever O/D thread you want.
lmk
Old Apr 14, 2007 | 05:16 PM
2xLS1's Avatar
http://www.timesert.com/html/gm.html
Old Apr 14, 2007 | 06:48 PM
I'll let him know, thanks a lot guys, appreciate it!
Old Apr 14, 2007 | 06:50 PM
brad8266's Avatar
lmk
Helicoils are ususally stronger then the original threads.
Old Apr 14, 2007 | 06:54 PM
Really? I was a little sceptical about puttin a helicoil in there too, but my buddy knows way more than I do and if he's willing to do it, then it's gotta be strong enough to hold.
Old Apr 14, 2007 | 07:32 PM
BLUEBALLS ZZ's Avatar
thanks for the kit and info guys. for some reason the stud pulled out before i got my first pass in been building these motors for years and this is the first time it has ever happen
Old Apr 14, 2007 | 07:39 PM
brad8266's Avatar
Yes they are usually stronger. They are made of cold rolled stainless steel, much stronger than all the damn aluminum threads in our blocks.
