(cam only) Texas Speed Torquer v.2 come in
#41
Originally Posted by Matt2105
Lol thats the most retarded thing Ive ever heard. If you spend 700 bucks for a cam swap to gain 40 hp but wont spend 100 to gain 10 then I just dont know what to say.
P.S. sorry to the OP for
#43
Originally Posted by Summit2345
I don't know how thats retarded when you can put a cam in a car and feel a huge difference in the car, and have a much lower e.t. or I can put a lid on my car, and probably not gain enough to feel a difference and maybe if I lucky gain .10 at the strip. I'm sorry if I think different, but I'm not trying to squeeze every bit out of my car to gain at the strip
#44
The fact is that its only 100 bucks...I mean hell, you can cut your neighbors grass twice for 100 bucks. Its like cheaping out. Its like buying new shoes, but not buying laces for them.
#45
read the last post on this thread and then tell me that a lid is worth a $100 when I can take that same money and get a tune, and make more HP.
https://ls1tech.com/forums/showthrea...no+results+lid
#46
#47
Originally Posted by oneBADDz
If you're cammed you need a lid even mroe than a stock car. If it = 10-15hp on a stock car, you REALLY need one being cammed. you're demand for air is much greater than stock
#48
You must have not read the post by Ed Wright the car only made 1hp on a bolt on car I'm assuming by the horsepower he listed. So I would say on a CAM only car it would at best only make 3-5 hp. When I go and get my car dynoed here soon I will Switch lids just to see what kind of difference it will make, and I will post results.
The problem is that you cant really measure what a lid does on a dyno because the cars stationary. The faster the car moves, the more air will be forced down its throat. Dyno numbers arent everything...
#49
#50
Wow, why such controversy over a lid? If the guy wants to get another lid he will. It's not like he sold his LS1, got a Mustang and is now a troll making fun of us. He actually posted something useful in this thread. For all we know, he may be living in his car and posting on here from a public library.
Now, back to stuff on the Torquer 2. I'd like to see more videos or numbers from the dyno or track as there are a number of those out there about to buy a cam such as myself.
Jason
Jason
#51
You must not have read the posts that explain to you what the one right after your last post did. A lid will produce nothing on a dyno, there is no positive air pressure put on the lid on a dyno. There is a reason everyone on the planet get s lid first. You're not the genius that figured out that it is a fable, you are a fool who is choking his cammed LS1. Don't go to the dyno to test it. Go to the track and make a few passes, then change the lid and make a few more. You'll steal whoever's lid you just borrowed when you see what you've been doing to your cammed car
#56
im starting to really consider this cam, it will be going into my DD. Im just worried that it is too big for a DD. Can some one chime in on its idle and drivability, I know TSP claims a like stock idle quality. Also what rpm are you guys shifting at?
#59
ok i just got this cam installed guys with tsp 7.4 pr ,dual springs.and comp cam lifters ..i seem to have a loud knock at idle more so than the sewing machine noise.im stock heads and gaskets .so i think my pushrods are fine.but it sounds like a lifter is bottoming out and can not figure out what the deal i s.oil presure is 40+ psi at idle .any idea what it may be also started the car with the valve covers off and notice very little oil coming threw the pushrods and dribbling onto the rockers .
