Another Dumb cam install question!
Ps I was reading the cam install guide-- bowlingSS and it said
*Remove the spark plug of the cylinder that you are going to change the valve springs on, and screw in the leak-down tester hose. A good seal is not 100% needed. Adjust your air compressor to approx 60psi on the hose, and hook it up to the leak-down hose.
What does that do, is it neccesary? Thanks Matt
Set the piston at tdc and if you have an m6 lock it there in gear. Put in the leakdown tester as instructed. If you see it losing pressure while you're compressing the spring, stop and tap the retainer to free it from the keepers then proceed. Having the piston at tdc is extra insurance so that if you do lose the seal and drop the valve it will just stop on top of the piston.
Taking the heads off has ALOT more involved the just unbolting them, and bolting them back on. First off pulling the heads in a f-body is a PITA because half the head is under the dash. Then you would have to spend a couple hours cleaning the block surface, and scraping all the old gasket off. You would have to have the heads cleaned up. Next, you would have to buy a new set of head bolts and head gaskets, and finally, MAKE SURE they are torqued back down correctly(im sure i forgot a few steps). Trust me man, if your only pulling the heads to change valvesprings, you wasting alot of time and money. Now, if you were going to replace the lifters as well, that would be a good reason to pull them off.
Ps. I dont have that tool to hold the lifters up when i pull out the cam,and the pen magnet deal seems preety sketcy... If i pull that sucker out how good a chance is it that one will fall?? If one does...Then what ? If my odds are good they will stay up, Ill go for it!
The pen magnet deal doesn't sound to good to me either, the lifters have some sort retainers to hold them up, but this is not good on its own, if one falls down your only option at that point is to remove the cylinder heads. Old engines only required to remove the intake manifold, but not on these engines. Just get the metal rods or wooden dowls and stick them in the hole-much easier and your set.
Would have saved me a headache. I wanted to keep mine as well, but I live in a townhouse with no garage and no room to store it.
