Putting heads back on
Old Apr 27, 2007 | 11:28 PM
LS1IMPULSE's Avatar
Default Putting heads back on
How many people have had problems with the lower 3 middle head bolts on the driver side. I cant get the damn things past the headers to get them in their holes not matter how I try, and my headers are stuck on the y-pipe pretty damn good.
Also what did yall use to clean the bolt holes, i spraye dthem wilt compressed air, clean them with paper towel dremeled the bolt and used that and theyre still wet !!!
Old Apr 28, 2007 | 12:00 AM
ATXCAMAROGUY's Avatar
you have to unbolt the headers from the y pipe and drop the driver header down. Although on my buddies car the header was a bitch to drop in/out so we just kind of moved it around depending on which bolt we were on. If your collecter is welded to the y pipe your probably gonna have to take a sawzall to it and get it re-welded.
Old Apr 28, 2007 | 03:41 AM
PREDATOR-Z's Avatar
And be patient
Old Apr 28, 2007 | 09:49 AM
LS1IMPULSE's Avatar
Originally Posted by PREDATOR-Z
And be patient
that my friend, is a quality I wish I posesed
Thanks for the help, I cant get those bolts in no matter how hard I try, weird thing is, I got the old ones out with the headers there ?!?!?!?
Old Apr 28, 2007 | 08:58 PM
Bill Bowling's Avatar
Did you get them in?
Bill
Old Apr 29, 2007 | 08:44 PM
juiSSed1172's Avatar
For the water, roll a paper towel up like a HUGE cigarette. Get it as tight as possible. It will work, it just takes time. (I just did mine today :o )
I ended up shop vac'ing the holes. Then I used the paper towels. Then I used the 'thread chaser' (dremel delight). Then I used more paper towels. Then I used the dremeled bolt again. It took forever, but it worked.
Old Apr 29, 2007 | 10:53 PM
LS1IMPULSE's Avatar
Yeah i got it done, everything back togehter, pretty much completely done, then when I went to put in Spark plug #8 I found out the threads in the head for that one were all F*cked up. So now the driver head is back off and I get to clean out the locktite again and call patriot tommorow for some new head bolts.
Old Apr 29, 2007 | 10:59 PM
LS1IMPULSE's Avatar
Bill
And yeah, I did...I had to take out the steering linkage and drop the headers out, they were easy to get to after that.
