is trick flow worth the money?
Originally Posted by 30th t/a
AFR, Trick FLow and ETP are all excellent heads. I know Trick Flow you have to run after market roller rockers which are more money to add. AFR's stock rockers are all you need. Im not sure about ETP heads.
That is correct.
And dont forget about the darts either, like I said earlier, I feel that all the aftermarket castings are priced accordingly and the darts are perfect for someone who dosent want to use a stock head, but dosent want to throw a lot into an aftermarket head either.
I will be doing TFS 215's also.
Hell i know people that payed 2700 for hand ported Stage 2 gm castings.
So i do not think the 215's are over priced at all imo.
TEA now does an LS6 stage 2 casting for 1320 bucks (less the price of 243 castings which you can buy new for 400 bucks from patriot) called their Trickflow killers. When I emailed Brian, he said they flow as much air and use the same VJ/valves/spring setup.
So for 1720 bucks you get a TFS equivalent head, just no thicker deck and increased PTV clearance. But then again you save 1000 bucks over the TFS heads. Just another option.
We have yet to see that head make power equal to the Trickflow's. Even though the flow numbers are close, I feel the Trickflow has an advantage with it's improved plug location and flatter valve angle/chamber design. Notwithstanding that is a killer head for the money.
You guys have any more results besides the auto car that did 10.80's at 126? I am going with these heads and am looking to pick up quite a bit from mildly home ported 806 castings.
What cam did the car in question run btw?
Marty
