The dredded "ticking" noise
First Thing: I have been hearing a "ticking" noise from what sounds like the top driver's side of the engine. I know the LS1's are notorious for lifters ticking, and I'm almost positive this is the problem. The oil pressure is great, and the ticking noise seems to go away when the car warms up. Is there any way that I could check to see if it is a bad lifter without pulling the heads off? I was told by someone to try using thinner oil (Mobil 1 5w30 full synthetic) first to see if the ticking stops.
Second Thing: If it is a bad lifter, is it extremely important to get it fixed RIGHT away?? Because I am on a limited budget right now. It's not my DD, so I do not drive it much. I want to put a larger cam in it in the near future, not sure on the exact size yet, so should I just wait to replace the lifters when I get a new cam installed. I want the car to remain very streetable, so I will not be going with a HUGE cam. Will the LS7 lifters work well?
Lifter changes on as LSX require cylinder head removal,so as long as your oil pressure is good..then it isn't your lifters..If your actually had a bad lifter,you would need to change it ASAP.This is because of the accompaning low oil pressure would evntually ruin engine bearings...Bad lifters also greatly reduce power output.
You have 2 easy optins. 1: Get a loud exhaust system, or 2: turn up the music.
First time I heard it I thought it was lifter tick too... maybe you're hearing the same thing? Just a thought
