DIY H/C install
Old May 7, 2007 | 09:22 PM
6']['9's Avatar
Default DIY H/C install
im leaning more towards doing my H/C install myself. I read on ls1howto and install university on how to do things. But i wanted to see if there are any things i may need to know so i dont mess anything up, before attempting to do this myself.
Heres what i have so far
Cam MS4
Heads assembled LS6 TSP
Head bolts
Gaskets
Ported Oil Pump
Double roller timing chain
new lifters
am i missing anything?
thanks
jay
Old May 7, 2007 | 09:42 PM
Deerhunter-Z28's Avatar
Make sure you have enough PTV clearance w/ those heads and that cam. Do you know what CC those heads are?
Old May 7, 2007 | 09:46 PM
6']['9's Avatar
i bought it as a package so im assuming its everything i need to get the job done.
TSP said its everything i designed to work together.
Old May 7, 2007 | 09:51 PM
waterbug1999's Avatar
What size gasket they recommend?
Also, people change out their crank pulley bolt as well. I did.
Old May 7, 2007 | 09:54 PM
6']['9's Avatar
dont know the size but i have it here its a GM # 12498543. Like i said i just told them what i want and they recommended this setup.
Old May 7, 2007 | 10:01 PM
Well, to be safe, I would double check... and, the CC of those heads as well.
Besides the crank bolt, I would say you need some hardend push rods as well..
Old May 7, 2007 | 10:07 PM
6']['9's Avatar
well i do know that they did some kind of angle job on the heads i think it was like 3 or
5 degrees. I forgot to mention that i did get the pushrods as well. im not to sure on the cc i would say its 60 but i may be wrong. They are onthe TSP site they are the PRC LS6 Stage 1 heads i also got the PRC double springs
heres the link
http://texas-speed.com/shop/item.asp...d=649&catid=40
Old May 7, 2007 | 10:09 PM
Mssingkid's Avatar
I'd also do an Under Drive pulley since you have to take the old one off anyhow. Pulley install tool (Sold by a member of the board) Depending on your mileage you may need new lifter cups. Mine refused to securely hold the new lifters in place. Exhaust manifold gaskets. Those self ratcheting wrenches are very helpful for tight places. I can go on and on... Take your time and you'll do fine..
Old May 7, 2007 | 10:15 PM
6']['9's Avatar
ive already got an underdrive pulley, racheting wrenches ok.. what are the lifter cups?
Old May 8, 2007 | 12:34 AM
jegten's Avatar
the lifter trays are what hold the lifters. they are made out of plastic.
i am doing my h/c as well, and i am getting a new set of those trays.
Old May 8, 2007 | 07:02 AM
6']['9's Avatar
where can i get those?
Old May 8, 2007 | 07:09 AM
slow trap's Avatar
if you have stock head bolts i would get a set of either arp head bolts or studs personally if it was me because the stock tty bolts are a pita .
Old May 8, 2007 | 03:58 PM
Mssingkid's Avatar
Dealer, you need 4, but they are cheap.
Old May 8, 2007 | 05:16 PM
cowboysfan's Avatar
not sure but, heads been stage 1 I believe they are 64cc chambrs. didn't check website just going by stage1 heads.
Old May 8, 2007 | 08:02 PM
I had 98K miles on my car when I did the H/C swap... My lifter trays were fine.
Old May 8, 2007 | 09:37 PM
6']['9's Avatar
this guy from the dealership said i need a torque angle wrench or someshit like that. anyone know what that is?
Old May 8, 2007 | 09:47 PM
I would assume for your head bolts... There is a process in tourqing down the bolts.. After you TQ them down to the proper TQ spec and in the right order, you have to give it another, whatever degrees, more to finish off the job..
Old May 8, 2007 | 09:50 PM
6']['9's Avatar
yeah it says to go over it 50 degrees then another 50 then 90. But can i do this with just a regular torque wrench or do i really need that tool.
Old May 8, 2007 | 10:37 PM
I would just rent or buy the tool to be safe. I mean 10* is not alot angle wise, but alot when turning a bolt.
Old May 8, 2007 | 10:38 PM
6']['9's Avatar
any links on where to get it? thanks for the help
