TrickFlow 235cc Heads ARE HERE!!!!!!!!!!
![](https://i88.photobucket.com/albums/k176/VengeanceRacing/DSC01335.jpg)
![](https://i88.photobucket.com/albums/k176/VengeanceRacing/DSC01334.jpg)
I believe we are the first shop in the country to have these on the shelf!!!
294 cfm @ .400 lift!!!!
347 cfm @ .600 lift!!!!
We will see how these do on our LS7 440 VERY soon!!!
Special pricing to the first 10 customers !!!
Originally Posted by DONAIMIAN
min. recomended bore size?
sheesh...lazy mods, but all is forgiven. it's not your forum to moderate
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
these things look like fun a big bore setup
Originally Posted by Mike@TEA
Minimum bore=4.030",Cost is $2569.00. Our standard spring package for this head
is our dual extreme pressure spring which is 160# seat 450# open rated for .660"
Here are the numbers from one flowed yesterday on a 4.030" bore.
Intake
.100 67
.200 147
.300 234
.400 289
.500 324
.550 335
.600 343
It will not be optimum on a 4.065" bore but should be slightly better than these
Intake
.100 67
.200 147
.300 234
.400 289
.500 324
.550 335
.600 343
Well after working on this for along long time we have finally finished our 235cc Trickflow head. This was originally supposed to be a 240cc head but when we cc'd the final version it came out at 235cc. It is built for a 4.125" bore and uses 2.08 and 1.600 valves it has a newly designed exhaust port which measures 86cc. Mid lift flow is outstanding as we had a goal of 300cfm @.400" but fell a little short of that. Flow numbers are as follows:
Intake Exhaust
.100 67 58
.200 146 124
.300 235 199
.400 293 244
.500 329 265
.550 341 272
.600 344 276
As always these were flowed on our Flowdata bench at 28" and the exhaust was flowed with a pipe.
Intake Exhaust
.100 67 58
.200 146 124
.300 235 199
.400 293 244
.500 329 265
.550 341 272
.600 344 276
Originally Posted by PowerShift408
That is absolutely insane. How do you think these would work with a 408 w/ a FAST intake setup?
I havent heard any SR TFS headed numbers, but ive been kicking around the idea of it. Never dealt with solid roller anything and im kinda curious.
I will post a graph of a similar combo, it is a Ford, but the heads are TFS High Port 240's that flow close to 300cfm @ .400" lift, and airflow is airflow. The engine was 10.8:1 compression and was an EFI single plane setup.
![](http://i67.photobucket.com/albums/h290/Brian_Tooley/hp240611hp.jpg)
