Best intake setup for Torquer 2 cam?
What heads and other intake are you guys with Torquer 2 running? I've got a 3500 stalled 4L60E and am looking to make as much power as I can with this cam.
Pick you up a set of PRC Stage 2.5 5.3 heads. Those along with a FAST 90 setup should make killer power.
And even if you dont do the heads, I would strongly recommend picking up the FAST setup just for cam only. The gains are well worth the money.
yah if you got the money got with a fast 90/90 set up.. ull see some nice gains with that. what times do you run with your car b/c ill be puttin a 3600stall and the same cam in soon
the times i ran aren't legit bc i wasn't running with tires and had an exhaust leak. so i like to pretend i never ran the car. next time i go out it should run high 11s. i've fixed the suspension kinks and exhaust leaks as well as added a new built tranny with that 3500 stall. after that i'm trying to break in to the 10s with nitro. my car is better on the track than it is the highway. prolly gonna have to rebuild the bottom end though.
i dont know about yall but i am going with the typhoon from professional products with a 85mm opening but they do offer a 96mm intake they are a good price and come with the fuel rails, i have a 3400 fuddle and ran a 12.4 with street tires and an ls1 intake with a smaller trick flow cam!!!!
