Need opinions on what cam to run now! Torquer 2 dosent cut it anymore
#61
I'm not going to offer any cam recommendations, as it's apparent to me that you have an idea of what you want, and simply want everyone to solidify your decision for you. However;
Your mods are;
Kooks Full Length Headers, Kooks Off Road Y-Pipe, GMMG Chambered Cat-Back Exhuast, 232/234 .595/.598 112lsa cam, LS6 Intake, 4.10 Motive Gears...
Common sense would tell anyone that it's either in your tune, or your driving, or a combination of both. You should be pulling that stock LS1 so freaking hard from a dig, that he won't be anywhere near you at third. If your talkin from a roll though, carefully re-inspect your gearing....
It's not the cam, although you do need some head work to maximize on it's full potential....
Originally Posted by Summit2345
the real reason I want rid of the cam is because a buddy of mine with a stock 6 speed Ls1 camaro that has a lid, and a cat back can stay beside me after third gear and thats what ****'s me off....
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#62
yeah its the cam making it run like crap
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
you sir, are an idiot. appairently you know more than all of LS1tech combined, cause 40 people have told you what you needed to know and you won't budge.
#66
the reason I'm not considering a MS4 is because everybody locally has told me that if I go that big I should go to a Trex, and from a dig when I had bald street tires I could be side ways spinning and stay beside him if that tells you anything. Its the top end of this cam that upsets me
#67
Originally Posted by oneBADDz
Why did you even bother making a thread here if you aren't going to listen to EVERYONE on the site that knows what they are talking about. Everyone else onthe site that has a T2 runs better than you, yeah it's the cam
#68
LS1 Tech Administrator
Unless your cam lobes have gone flat, your cam is probably not in at the correct intake centerline. It's possible that you installed the cam 1 tooth off from dot to dot. It happens. If chain has lots of slack in it, your valve timing will be retarded and you'll have no bottom end torque. Lots of things point to something other than the cam.
Whatever you do, make sure you degree the new cam you install and always add a fresh chain to it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#69
Originally Posted by Mr.MartyStone
And there is the problem. How do you know if you're down on power at all? You don't. Put it on the dyno.
Marty
Marty
Summit, screw dyno graphs. Look at the track times, and the way the cars drive. I realize these guys are correct: when I put my setup together, it wasn't even for best track times. It was for drivability. And I got it. But my times are disappointing too. Listen, when Bluecat gets his dyno working, we'll both work on figuring out what's up with our cars. Until then, get to the track this Friday, or be forever ridiculed!
#70
Whatever you do, make sure you degree the new cam you install and always add a fresh chain to it.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#71
I positive the cam is not off a tooth because i had three people look at it to make sure. The chain is the original chain on the car, and the car only had 23000 miles when I did the cam change. The car now only has 26000 miles.
#72
Originally Posted by LS1rulz
From what I can tell, it's pretty basic: he knows because he isn't any faster than before, as judged by racing his buddy's car. Not the most scientific test, but it's a very easy way to tell.
#74
I wish I could go to the track, but sadly I dont have a clutch that will hold up. Im not worried about the dyno I want to out run a stock LS1 at least.
#75
Two MAJOR issues...
HEADS and TUNE
Heads, especially the compression will turn a slow revving sluggish cam into a snappy powerhouse instantly. Compression is a HUGE requirement that only gains importance as you go bigger in duration.
The tune is equally important in terms of drivability and power production. Even if youve managed to get your fueling in line, theres a good chance youre running too little timing in the mid range areas. This will create a very sluggish feel on the street and could easily turn your cammed car into a turd. Not to mention that simply going by your BUTT DYNO, youre not likely anywhere close to producing max power. Do you even have a wideband on the car? Without one, your tune in no way should be considered comprehensive.
Youve managed to disregard just about every intelligent post in this thread. You started fights with pretty much all the top players who know this very subject. Youre throwing away valid comments simply because they dont coincide with your preconceived ideas.
Doing things your way is what go you here, driving a cammed car thats no faster than a bolt on car. Please listen to what these guys are saying, and listen with an open mind. They have years of experience under their belt. Theyre offering you their wisdom free of charge. Theyre trying to help drag your car out of the hole its in. You can be fairly certain, the Torquer 2 is not at fault.
HEADS and TUNE
