Compression Question - 5.3L Heads...
Old Apr 30, 2003 | 10:36 AM
02bluess's Avatar
Default Compression Question - 5.3L Heads...
Anyone out there know how much compression 5.3L heads milled .015 would make on an LS1?? I'm thinking ~ 11.4:1??
I've got LS1Edit, so I'm thinking I should be able to pull some timing and run that compression on 93octane. Thoughts??
TIA
Old Apr 30, 2003 | 10:46 AM
Fireball's Avatar
Default Re: Compression Question - 5.3L Heads...
FWIW, I have .040 off my 5.3L heads and run fine on 93 octane
Old Apr 30, 2003 | 10:50 AM
02bluess's Avatar
Cool!!! That's what I wanted to hear
Old Apr 30, 2003 | 01:29 PM
Sears's Avatar
!Dial-up Director
You should be ok on 93 with the proper tuning.
Justin
Old May 1, 2003 | 01:42 PM
TEA Brent's Avatar
The compression ratio on a 5.3 milled .015 is around 11.0:1
Old May 2, 2003 | 12:05 AM
Bad02WS6's Avatar
Hey Fireball. Aprox. What is your CR with .040 off?
444rwhp , What are you calling a small cam?
Thanks!!
Old May 2, 2003 | 02:40 AM
LARRY01Z28's Avatar
Im getting .020 shaved on 5.3L heads and i was told it will be 11.2 CR
Old May 2, 2003 | 04:37 PM
Fireball's Avatar
Thanks!!
Jason99TA told me its probably ~11.8:1. I haven't CC'ed the combustion chambers to be 100% sure though. Well my cam is small by today's standards...was big at one time
232/232 .574/.574 112
Old May 2, 2003 | 05:21 PM
Tin Indian's Avatar
I may be mis-informed, but I can't see how you guys expect to run todays pump gas with 11.2 to 1 and above compression ratio.
With my TEA 5.3L heads (milled a mere .003"), my CR is 10.8 to 1 (63cc chambers). At that, 92-93 octane pump gas is ok, but pushing it as far as knock retard is concerned.
Sure, you can take some timing out of it with Edit, but there comes a point where there is nothing gained by increasing CR, while pulling timing out of the motor.
Just my opinion,
Ron,
Old May 2, 2003 | 06:36 PM
Bad02WS6's Avatar
Hehehe!! Thats still a big phucker in my world!
You've got to be running valve reliefs in the piston's..Yea???
How did you get the cam in with .040 off the heads?
Thanks alot!!!
Old May 2, 2003 | 07:56 PM
Vents's Avatar
"I may be mis-informed, but I can't see how you guys expect to run todays pump gas with 11.2 to 1 and above compression ratio. "
why not? i know a few LT1 guys that run at 12.2:1 on 93. i think this general rule or, "myth" as i like to call it, has more to do with your specific application rather than anyone else's opinion. im not bashing, im just saying that if you are good enough to get away with it... go for it.
Old May 2, 2003 | 08:14 PM
Fireball's Avatar
I have my total timing cut to 26 degrees for street use, but I've dynoed and saw absolutely no horsepower gains going from 26 to 32 degrees (and everything in between) when I dynoed on good gas.
I pulled 440+ RWHP on 26 degrees.
No KR at all on 93 octane with .040 milled off my 5.3L heads. Then again my dynamic CR is alot lower running a 230+ cam
Old May 2, 2003 | 08:15 PM
Fireball's Avatar
Thanks alot!!!
I had to cut .055 off the tops of the pistons to get .070 PV clearance on teh intakes. Exhausts has plenty of clearance
