cant turn?
Old May 30, 2007 | 09:21 PM
SLP4CamaroSS's Avatar
Default cant turn?
ok got my cam in and everything and check the ptov (it cleared .070/.110)and it was turning over by hand easy with the heads off now i put it all together and try to turn the crank by socket and rachet and it move maybe 5 valves and stop and it makes a vacuum kind of noise. is the compressed air (vapor lock) in the cylinders making me not able to turn it the crank?
Old May 30, 2007 | 09:24 PM
ArcticZ28's Avatar
Are the plugs in it? If so, take em out.
Old May 30, 2007 | 09:27 PM
yes oh ok i will do that
Old May 31, 2007 | 10:36 AM
i did that and i got to turn it about 180degrees and it stops
Old May 31, 2007 | 10:38 AM
PAGregSS's Avatar
You may have put the wrong bolt in the cam retainer plate. It's easy to mix them up and you may have put a longer bolt in and it's protruding into the block and the crank is contacting it.
Old May 31, 2007 | 10:47 AM
ok i loosen up the rockers and now it turns i guess it had it to tight. but i only had it down to 22 ftlbs
Old May 31, 2007 | 11:27 AM
ok got it working forgot to put the pedalstal back on. on one side
Old Jun 1, 2007 | 07:32 AM
PAGregSS's Avatar
Doh! Glad you figured it out.
