Ms4 ????
Ms4 ????
I have long tubes and ORY and 3600 vig, I will be sticking in the MS4 soon and have it tuned. How will it run without lower gears? I do have a decent size stall so I was told with the tune it should do all right.
ummm i would definitly do gears. they will help out immensly. if you dont want to go big i would go with 3.73. that stall is kind of small for such a big cam but youll be fine
well I just want it in now for the sound just to drive with everyday. I'm not to concerned with track times right now, don't have funds for gears. I just don't want the car to buck real hard.
well i meen what are you goals for the car? do you really want a big cam just for the sound? also is this your DD? you can go with a smaller cam on a 110 or 111 ;sa and get that thing to lope nasty without giving up a lot of drivability.
I heard a million cams and MS4 just has that perfect lope, I don't car about drivabilty too much plus the guys at HPE can really tune good. I just wanna drive it regular cam/stall/exhaust for now and later do the 12bolt/lower gears, fast 90/90,pulley.
oh ok then yeah go for it. i would do a pulley though when you do the cam swap b/c i meen youll be right there so why not do it then. other than that yeah you'll ne flying but i would try and get the gears and 12 bolt soon if you can b/c these 10 bolts suck ***. im waiting for mine to go out and then 12 bolt here i come
Ms4 deff has a nasty chop to it. I've also thought of dropping one in my mill, but myte give the hellion a shot. Anyway, ms4 and tsp 237 grinds both sound good, but i'd think you'd enjoy the ms4. Get a good tune n you'll be ok.
cheers
cheers
