Why isn't there a gasket between the oil pump and the block?
It just seems odd to me that the oil pump bolts directly to the block, and no gasket or RTV goes around the hole where oil goes from the pump to the block. My new block has some scratches around there, should I put a light ring of permatex around it? It's already together but I don't have the balancer on yet, so it would still be easy at this point.
No no no! Leave it alone! You have two highly machined surfaces, no gasket or RTV required! This is oil you are pumping, not air. If you are saying the mounting surface on the block is damaged, that's a different story.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Originally Posted by GuitsBoy
I'd install it dry. The surfaces are precision machined and finished. I wouldnt chance a thin layer of rtv skewing the pump out a thou or two.
The block has alot of scratches in that area. The pump is back off, I will post a pic and see what you guys think
