LS6 springs + cam....worth it?
if you're on a budget why are you considering swapping heads. unless you're planning some ported ones it's not worth the hassle.
ls6 heads stock will gain you about 10-15hp give or take. while a good set of ported ones could yield upwards of 40-50hp on a cammed motor. so at the expense of gaskets, head bolts and the heads, staying with stockers is pointless.
2> doesn't needed to be reved to the moon
3> I am looking at a cheap budget build
Find a used TR224 on a 114LSA
> Great all around cam (Strong undercurve)
> Max rev /shift 6500 rpm
> Buy cam used. You can get PP stock cast 243 castings with Duals in the neighborhood of $700
All together if you do the install you still are looking at around $1500 + tune.
no qustion go for TSP 228R (texas speed performance)
and you will love your car to death
this cam has the same almost the same performance as the tr224 but with better horse power and alot of power under the curve
good luck.
you will rev it just the same or maybe 100 rev more like you will end up doin 6600
plus alot of power under the curve
the TR244 is the cam to beat it will never steer you wrong GO FOR IT
SECRET WEAPON : GO 3.73 rear end
