Cali guys please help...
Old Jun 22, 2007 | 05:16 PM
ZMONSTER!'s Avatar
Default Cali guys please help...
Im trying to decide what to do with the Z and cant make up my mind, what type of N/A set up do you guys run? my perfect set up would be for a 400-450whp, reliable and fairly (+or- 20mpg) gas friendly DD that can pass smog. can I do this with a simple head and cam package? If so who's? If someone can give me a no-**** this works in my car it would be awesome.
Old Jun 22, 2007 | 07:18 PM
GTObsessor's Avatar
TR 224 on a 114 LSA with Livernois LS6 heads is a combo i've seen work very well and make around 420ish rwhp with a tune and is very streetable. You'll need supporting mods (springs, retainers, pushrods, etc) along with a good tune and it's a good idea to replace your oil pump (with a ported and shimmed pump like the one from TR) and your timing chain (with an LS2 set) while you have everything apart. Make sure you get the gaskets you need and any loose ends. THere are some pretty good guides around here if you search around. Just make sure you have some decent high-flow cats on your exhaust and you should be good to go.
What supporting mods do you have so far? LTs? Lid? anything? If not, the CheaTR package from Thunder Racing is a better deal for you since it's made to work with stock manifolds/cats and provide near 400 rwhp but the afformentioned setup with longtubes (not legal, but can pass smog if visual is exempted by a 'nice' smog guy) will make more power/tq.
Old Jun 22, 2007 | 07:35 PM
Mystic 98 TA's Avatar
+1. Depending on the tune there have been cars with CheaTR and AFR 205cc (i think) heads that put down aound 390rwhp on stock manifolds.
Im putting down 340rwhp with my 98 TA through the stock (shitty) manifolds, lid, LS6 maf, FTRA, pulley, and a non-adjustable Borla cat-back. Those ore my only mods. With my 3.73s i average 20-22mpg with equal street/hwy driving. This car is my DD.
Old Jun 22, 2007 | 11:38 PM
SmaknaSS's Avatar
TR224/224/114 LSA and ported LS6 or AFR205 would work but I think you'll need LT headers to pull the power your looking for out of that setup.
BTW I have TR224, AFR 205's and QTP long tubes and am making 421 RWHP and 403 TQ (Corrected)on all motor.
Old Jun 23, 2007 | 08:34 AM
Dave@LivernoisDSS's Avatar
I have guys making that much with our stage 1 heads and smaller cams than we normally suggest... Our stage 2 heads and stage 1 cam generally make 420ish on our dyno seems to be lower than most. We had a customer in with someone else's stage 2 heads and a 224 cam and only make 390rwhp.
Old Jun 23, 2007 | 09:48 AM
Steve Gunn's Avatar
If you are going to pass Cali smog (legally), you'll need to run cats in the stock locations which takes LT's out of the equasion. You might want to set a more realistic goal of around 380-400 rwhp N/A... then spray it with a small shot to run with the guys who get their certificate by other means.
Old Jun 23, 2007 | 10:08 AM
SilverC5Vert's Avatar
My car made 420 RWHP Livernois stage 1 heads and the other mods in my sig. I was very happy with the performance for the money spent.
-Rick
Old Jun 23, 2007 | 01:36 PM
ZMONSTER!'s Avatar
Wow thanks guys keep em coming!
Old Jun 23, 2007 | 01:40 PM
00Formula00's Avatar
Im going milled AFR 205's, TSP 224R on a 112lsa and I have the rest of the mods in my sig.... With a really good tune I will pass
Old Jun 23, 2007 | 01:41 PM
O and as for the LT problem, I have a guy who will skip the visual for me... try to get that, because you can pass with LT if the "smogger" doesnt look
Old Jun 24, 2007 | 07:03 AM
ZMONSTER!'s Avatar
what other supporting mods would I need for a head and cam package? what about internals? pistons, rods, crank, etc....
Old Jun 24, 2007 | 08:44 AM
GTObsessor's Avatar
Usually not an issue. Might want to replace the rod bolts if you're gonna spin the engine up high but with a mild H/C setup, you shouldn't have to. Those things do become a factor with FI setups such as large shots of N2O and high boost applications, however.
Old Jun 24, 2007 | 03:03 PM
ZMONSTER!'s Avatar
thanks guys, one last total newbie question...what is lsa?
Old Jun 24, 2007 | 03:31 PM
ZMONSTER!'s Avatar
Never mind, "lobe seperation angle"....I will never understand the black art of camshafts
Old Jun 24, 2007 | 03:45 PM
52172's Avatar
I was putting down 415/403 with a comp 222/224 .581 114 cam that would pass the sniffer and all the bolt ons and short tube headers even. It can be done.
Old Jun 24, 2007 | 03:48 PM
ZMONSTER!'s Avatar
What type of cam should I be looking for if I was running mid or shorty headers, not stock. I dont want to have to worry about the visual inspection so ill probably go mid length headers with 2.5 catted y-pipe and cat back(to be determined). I saw a package from TSP that was just that. so what cam with those and 205's? Also what else exactly..."You'll need supporting mods (springs, retainers, pushrods, etc) along with a good tune and it's a good idea to replace your oil pump (with a ported and shimmed pump like the one from TR) and your timing chain (with an LS2 set) while you have everything apart." is that it? any other reccomendations?
Old Jun 24, 2007 | 09:56 PM
jermzz's Avatar
My setup passes smog every time
Old Jun 25, 2007 | 08:45 AM
ZMONSTER!'s Avatar
ya with a 427 im sure you have no problems...anyone else?
Old Jun 25, 2007 | 10:31 AM
Jermzzz is a LIAR!- by far the baddest "ls1" camaro in nor cal though.... haha nice try
Old Jun 26, 2007 | 12:27 AM
Formulated's Avatar
With mid length headers and an aftermarket y-pipe, catted or not, you will need to worry about the visual inspection. By the letter of the law, you need to use the stock cats in the stock locations. That means the closest you can get in CA is shorty headers. Of course, though, if you have a place that will be gracious on the visual, then go ahead. But if that's the case, just put on long tubes.
