Mti Stealth cam?
Old Jun 26, 2007 | 08:10 PM
headed-ws6's Avatar
Default Mti Stealth cam?
Im going with the stealth cam 1 from mti and wanted to know and info on this cam. How much HP and TQ it makes and if you had heads how much power did you make with it. I am building a new motor and want to go with this cam and some 59cc LS6 heads from patriot. Let me know and thing about the cam.
Old Jun 27, 2007 | 07:55 AM
PREDATOR-Z's Avatar
220/220 .581/.581 115+0 LSA
Good all around cam with Stealth idle. If you are going with PP 59cc heads this cam is too small for the PP head runner size. I would move up to a X1 or TR230.
If Stealth is what you're after then this custom cam:
223/228 .636/.588 114+4 custom LSK/XE-R lobes, still tame at idle but plenty power everywhere.
Old Jun 27, 2007 | 11:30 AM
headed-ws6's Avatar
What cc size would be good to run on the mti cam? I am shooting for 11 in compression and thats why am thinking about the 59cc heads. Would going with a bigger chamber on the heads be better?
Old Jun 27, 2007 | 12:34 PM
PREDATOR-Z's Avatar
If you are set on Stealth I then PRC stage 2 (2.02/1.57) 5.3L
Mill the heads ~.015 (3cc mill) for a 60cc.
That will yield a ~11.29 SCR and 8.55 DCR, just perfect with stock gaskets
Those are 220cc intake runners, they come with dual springs to .650 lifts.
Another way is to get the same heads but no mill and run a .040 Cometic gasket. I prefer that way because you get better quench and your heads are unmolested if you want to run a bigger cam in the future. All you have to do is get new gaskets then.
Old Jun 27, 2007 | 01:14 PM
Pimpium57's Avatar
^^How quiet would that cam be compared to the SII? If more audible, what would you change (specs?) to make it even quieter?
Old Jun 27, 2007 | 01:35 PM
PREDATOR-Z's Avatar
That is a -2* overlap, it will have a tiny lope, but with cats and magnaflow muff it is as quiet as the SII. It has a nice muscle car purr.
Old Jun 27, 2007 | 07:05 PM
Pimpium57's Avatar
Is that the cam you ran in your Vette?
Old Jun 28, 2007 | 06:02 AM
PREDATOR-Z's Avatar
No, my Ex-C5 I ran a Super Stealth cam 210/224, .555/.568 115+1 with 1.85 rockers.
Quiet as a mouse with stock stall, ported TB, Hallteck, stock manifolds, X pipes, Magnaflow catback, tuning. 374whp/382wtrq.
I didn't want it to act any different than stock. Had I thrown a set of AFR 205s on I would have made the 400rwhp mark, but I sold it to get a C6.
Old Jun 28, 2007 | 10:27 AM
transamfreak01's Avatar
223/228 .636/.588 114+4 custom LSK/XE-R lobes how will this cam sound w/ out cats?
Old Jun 28, 2007 | 10:46 AM
00cls1camaross's Avatar
i imagine it would depend on the catback. Bassani Quiet thunder will probably not hear it because it is so quite. LM 1 you could hear a lope
Old Jun 28, 2007 | 11:02 AM
Pimpium57's Avatar
Mark (Predator) and I talked a bit more about this cam....it'll be pretty stealthy given a quiet catback like 00cls1 said, but anyone who knows a thing er two about LS1s will know the car is cammed.
Old Jun 28, 2007 | 11:06 AM
PREDATOR-Z's Avatar
The lope will be kinda in between TR224 112 (0* overlap) and TR224 114 (-4* overlap)
