F14 problems...
It seems that my Friends 00 Ls1 wouldn't start with this cam put in. We went threw each and every thing we thought would be a problem including injectors, map/crank/cam sensors. Even changed the Computer and Mass air from my car and put it on theirs.
The car wouldn't start. but we figured it out to be the only reason it wouldn't start was because the F14 was in there. We put the car at top dead center and went dot to dot (stock timing gear and chain).
My question here is if we went to install the F14 again would we need to possibly degree the cam, and also if we did need to how much. My friend can't seem to find the cam card but on the cam is written F14 +4.
Any and all suggestions welcome.
Thank you,
Shane
Thank you,
Shane
Get this they sold me an f15 that they ground the cam pos sensor 180 deg backwards so i had to remove the intake and swap the two wires around and it started but now my car dosent start for **** and it runs rich as hell. try that out tho
Sry no pics the cam was already in the car when i got the bad news
Just try pulling the wires out and switching them around and see if it will start. What happens when you try to start it? pops a bunch?
Just try pulling the wires out and switching them around and see if it will start. What happens when you try to start it? pops a bunch? Shoudl have no prob starting even if its not degreed perfectly. Would have to be a ways off to cause problems. Have you checked compression? Verified that youre getting spark? Smelling fuel out the pipes? Has any tuning been done? It might be difficult to get it to start if you still have stock tune in there, but I would think youd get something out of her.
The only reason the car wouldnt start is because of the cam.
We have the stock cam in there now and it runs like a champ.
What would be a reason for the f14 being in there and not running.
It would turn the motor over and just pop.
Not even a normal backfire, only once ina great wile, more like a fuel compression pop.
Originally Posted by ditty24
who ****** knows with them lol! Its not the first time and i bet it wont be the last they have a bad batch of cams! Call them up tho
he said it was a bad batch and he is sending a new one back to us. we need to send ours back also. but i asked if another cam was possible instead of the f14 and no word yet.
Originally Posted by shanev8
said he would gladely upgrade to any came, im thinking we are gonna stay with the f14 though. John has been a big help, Thanks Sigforty for letting me know to pm him.
Jon is a great guy to deal with, i promise u that no harm was intended and it does not make their shop look bad at all, all their cams have been proven and whenever there has been a problem, theyve always came through and took care of everything....**** happens, but they they are a great company to deal with and i will continue to deal with them in the future
