Porting Dart 205 Heads
HEY guys i am just wanting to know if anyone here knows about porting dart heads(205). i am trying to find out some info on how far can you go and what to do to port them
and also how much hp i will gain from porting heads
we are currently making 430hp @wheels N/A and 520 hp @wheels with 100 shot so what should i see
the setup is a 232/236 cam with dart heads (been surface shaved a bit)
thanks alot guys and hope someone can help me out
Not sure how much hp was gained, but here's the post telling how much cfm was gained. https://ls1tech.com/forums/generation-iii-internal-engine/514551-dart-225-after-info.html
Isn't there a rule of thumb saying for x amount of cfm, that equals one hp? Isn't it something like 5cfm = 1hp?
Originally Posted by Xtnct00WS6
Not sure how much hp was gained, but here's the post telling how much cfm was gained. https://ls1tech.com/forums/showthread.php?t=514551
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
BTW it is more like 1 cfm=2 hp..
ok can someone tell me what these are cause i dont under stand i guess they are like flow rates or something??
Lift---Intake---------Exhaust
200---108vs143----108vs121
300---194vs207----164vs170
400---246vs261----207vs220
500---281vs291----231vs241
550---288vs293----237vs245
600---294vs303----241vs248
625---290vs306----242vs250
650---286vs311----242vs252
675---282vs313----
700---278vs315----
Here are my afters
intake exhaust (NO PIPE)
200 134 104
300 201 142
400 255 178
500 297 205
600 321 220
700 326 224
800 329
675---282vs313----
700---278vs315----
Here are my afters
200 134 104
300 201 142
400 255 178
500 297 205
600 321 220
700 326 224
800 329
Originally Posted by Beaflag VonRathburg
Amusingly enough he's banned. Not to mention he's a dick.
You have no idea why he was banned.
675---282vs313----
700---278vs315----
Here are my afters
200 134 104
300 201 142
400 255 178
500 297 205
600 321 220
700 326 224
800 329
675---282vs313----
700---278vs315----
Here are my afters
200 134 104
300 201 142
400 255 178
500 297 205
600 321 220
700 326 224
800 329
You can port a set of Dart 205s out to the equivalent of a set of ported Dart 225s. The heads are pretty much the same except for the smaller valves and intake runners in the 205. That relates to more meat to take away with porting in the 205s.
OWN3D BY MY PROF!
Originally Posted by Stang's Bane
Actually he is not. The people that know him personally, know that he is a pretty nice guy. He will take the time to explain WHY something works rather than just "that it does"
You're right I don't have any idea why he's banned, but it doesn't matter to me. One less internet know it all that think's they're the begin all, end all of everything is out of here.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
If you want a good porter who actually put down solid results get in touch with Greg Good. V6Bird another guy on here does a lot of work with them. He's also banned, but he actually puts down great results.
My experiences and others with him haven't been the best. That's why he would explain to us about L92 cams? Then put down rather crappy numbers and think his work is amazing.
Bret makes his living by specing out cams. So I wouldn't expect him to give out his reasons for cam specs.
I know v6bird also, matter of fact I talk to him almost every day. Ask him his opinion of Bret.
Bret doesn't think he knows it all, but he does know enough to be one of the best in the country.
The only result you have seen out of Bret for a L92 cam was the first one that WKMCD had. Come to think of it, that was one of the very first L92 builds period. Nobody hits it out of the park on the first swing everytime. The biggest difference was his first swing was broadcast on national televeision more or less. I would call it a solid double, based on the fact that he gave the customer exactly what he wanted. I happen to know quite a bit about that whole situation, so I am not just spouting internet hearsay.
Bret Bauer eats rocks and ***** gunpowder; he knows his stuff and is not a Jelly Bean. I can tell you I have had very good expierences with him. Wait till the LSX race in October is over. Look at who the #1 qualifier is, and then speak negatively about Bret's work.
OWN3D BY MY PROF!
![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
