Help Motor Problems
Old Jul 16, 2007 | 05:51 PM
1FSTBRD's Avatar
Default Help LS1Motor Problems
Well guys I raced my car on Sat.I won the first race,on the second I hurt my motor.It is making a realy bad ratiling noise,sounds like its coming from the passenger top side of the motor but can be heard under the car also.I havent lost oil press and the car starts up fine.I started it yeaterday and when I started it she rattled realy bad and 30 secs later it stoped and olny could be heard when reved.Im looking for some opinons and ideas.It is a 98 LS1 with 35k on the car.I think it could be valvetrain or a rod knock but I hope not.
Old Jul 16, 2007 | 05:55 PM
waterbug1999's Avatar
did you over rev it?
Old Jul 16, 2007 | 05:56 PM
1FSTBRD's Avatar
I dont think so,It does have the rev limiter.But I dont know for sure!It is a auto car.I did install a 3200 stall and new gear without a tune!
Old Jul 16, 2007 | 06:11 PM
1FSTBRD's Avatar
ttt
Old Jul 17, 2007 | 03:54 AM
1FSTBRD's Avatar
to the top
Old Jul 17, 2007 | 06:17 AM
nobreaks254's Avatar
maybe a broken spring?
Old Jul 17, 2007 | 07:49 AM
bjamick's Avatar
My LT1 made a ticking sound for about 2 months, then she locked up while going down the interstate. So my advice is if you dont want to have to buy another engine, then you need to park it and find the culprit.
Old Jul 17, 2007 | 08:12 AM
SSANIMAL's Avatar
Yeah Don't Drive The Car I Had A Bend Pushrod On My Ls1 Few Days Later Timing Chain Broke Had To Replace Valves On Heads It Sucked But Was Just And Excuse To Upgrade.
Old Jul 17, 2007 | 08:52 AM
brad8266's Avatar
cracked valvespring was my first thought.
Old Jul 17, 2007 | 12:33 PM
1FSTBRD's Avatar
I was thinking a valve spring also,but the car doesnt realy sound like its missing and it isnt constint.It comes and goes but is always there if you rev it.I am not driving it anymore.Im gonna change the oil and filter thriough it today,then start taking the valves off.
Old Jul 17, 2007 | 02:27 PM
1FSTBRD's Avatar
ttt for more opinons,alot of friends are telling me I probly spun a bearing
Old Jul 17, 2007 | 08:18 PM
RIDINFILTHY's Avatar
Dont Drive It Just Take It A Part And Find Out!!!!
Old Jul 17, 2007 | 10:40 PM
jermzz's Avatar
If you spun a rod bearing, it'd be pretty apparent..if you spun a main, your pressure would peg cause the oil holes wouldn't line up properly.
Chances are it's in the valvetrain somewhere. did you pull the valve cover off?
It's the fact it comes and goes that makes it hard to figure out.
I had a friend we just put a cam in his car. it was constant but making the same noise. He had two broken stock pushrods.
Old Jul 18, 2007 | 07:06 AM
1FSTBRD's Avatar
well I figured out that the inital noise when you start the car is dry start,so the oil pump is def no good weather or not that caused any further damage,I will wait till I get the oil pan off to inspect the bearings.The other noise is coming from the top rear passenger valvetrain.I hope to have the valve cover off today.
Old Jul 18, 2007 | 01:36 PM
1FSTBRD's Avatar
I just drained the oil and filterd it out nothing came out on the screen that I could see.There was a spec of metal and some dust stuck to the oil drain plug!
