Tr 230/224 Vs Tr 236/230
Originally Posted by ws6_bandit
please explain??
this cam puts up amazing #'s with a great power band. and its not a huge cam by any means.![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by mudflap1989
You said that you you would like to spray, right? I would do a traditional split with spray, but that really depends on how big of a shot you are running. It also depends on what your intake and exhaust setup is as to whether you should run a traditional or reverse split, which I've not heard you mention what you will be running.
As far as spray goes im only goin with a 100 shot until i do some work on the bottom end.
Correct me if im wrong but i think i would have to go with a larger traditional split cam to make the power the reverse split tr230 would make. maybe in the range of an MS3...
