Tr 230/224 Vs Tr 236/230
Ok so their both reverse split cams.. Is the 236/230 going to produce more power than the 230/224.. i would assume so but im not sure. Anyone have any #'s on the 236/230, i havnt heard much about it. Im guessing the 236/230 is a bigger version of the 230/224???
Originally Posted by SLP4CamaroSS
i heard good things about the tr230/224. friend had on midrange was strong
Originally Posted by silver-mod-o
go with the smaller of the two IMO.... whats the lift on the respective cams? LSA?
236/230 .599/.575 112 LSA
Thats what im leaning towards but i was curious bout the larger one.Nobody seems to have heard much bout this cam..
Originally Posted by ws6_bandit
230/224 .575/.563 111 LSA
Originally Posted by boostedrs
I actually have this cam. My #'s arent the highest but I do have 4.10's and 12 bolt rear. It has a really nice top end powerband. As soon as you hit about 4.5k It just opens up. Bottom end I think is kind of sluggish but up top it feels great. I am also spraying a 200 shot on top and my god it feels great then. If you have any questions or want me to post the dyno sheet let me know.
I have a similar cam (CompR custom ground 236/230 .601/.591 114+2LSA) in my car that has a similar powerband(not until 4.5K do you feel any pull). Its actually slower then w/o the H/C until 4500RPM when it starts picking up.
The shop that did my install installed the cam a total of -4degrees(Don't know why, I'm kinda upset about it). How much do you think (after P to V clearance is determined) it would benefit me to install the cam straight up or even +2. This H/C setup made 450/404 in another car at -2degrees on the cam. Mine only makes 428/379. I like the cam, although I hate not having any power on a stock bottom end till 4500 to 7000. Different cam, or will advancing the cam make a noticible difference in the offset of the power band, for more low/midrange?.
Originally Posted by TXZ28LS1
go with the TR 230/224!! its a proven performer.. the 236/230 that ive read really hasnt been so popular on this site. search for a guy named gillbot, hes running the tr 230/224 in his auto and made 399rwhp on stock heads!! thats with a 4k stall i believe.
I'll prolly end up goin with the tr230. It seems that cam runs really good on stock heads and pulls hard even in the low rpm's. thats exactly what im lookn for. Hopefully ill have some #'s up for y'all in a month or so. Thanks for the help guys!
Originally Posted by QuickdomesticRacer
Is Reverse split preferred?
Yup. ive read his post. Amazing #'s for an auto.... cam only!!
It's a great cam with stock heads and if you want to do cam only. It CAN perform very well with ported heads, but if you are going to go through all that effort you could probably get a custom ground cam to match your heads and make that much more.
Just be sure to get the proper supporting parts with it and get a GOOD tuner!
the 230/224 is much more streetable and has great midrange......it all depends how much your going to drive your car and your set up, personally im going to install this cam in my camaro
Originally Posted by mudflap1989
I suggest going with a traditional split.
this cam puts up amazing #'s with a great power band. and its not a huge cam by any means.
Not exactly... Ive just heard many good things about the tr230. I would like to spray tho and reverse splits arnt great for that. Why.. other suggestions??
Mild LS1 street setup? Reverse cam for the win!
