dry sump
Old Jul 29, 2007 | 07:16 PM
Big Bird WS6's Avatar
Default dry sump
dry sump.
any help please.
i want to dry sump my motor. i have a built ls6. i don't know where i hook every thing up. or where to get pump. or any of that.
please any thing can help
Old Jul 30, 2007 | 08:26 PM
JPH's Avatar
JPH
ARE is a good place to start. they have complete packages. if this is a street motor, don't waste your money.
Old Jul 30, 2007 | 08:28 PM
Futral's Avatar
A dry sump is really on good for 8000+ RPM or serious road racing. Shoot me a PM and I can help you out with everything you will need for your application if you need one.
Old Jul 30, 2007 | 08:54 PM
where do i get ahold of are
and why not for a street motor.
"LS7" Zo6 street car dyr sump
Old Jul 31, 2007 | 11:51 AM
JPH's Avatar
JPH
www.drysump.com is how you get ahold of ARE. good luck.
Old Jul 31, 2007 | 12:41 PM
DONAIMIAN's Avatar
The C6-ZO6 dosent use a true dry sump system, but it still gets the job done well enough.
An aftermarket dry sump system is a little more complicated and requires you to loose your a/c in order to use the scavenge pump. By the time your done youll easily be 3000 dollars lighter.
Old Jul 31, 2007 | 12:59 PM
slt200mph's Avatar
The Z was designed for high G force cornering ... and with the stock sorry assed goodyear run flats it will do 1.05G on a skid pad..Jeff Gorgon was doing some hot laps up at road atlanta and pulling 1.27 G in some corners..with real tires the car will do much beter than that .. no oil starvation with that system..unless you are going to a road racing track no use in spending the money..
Old Jul 31, 2007 | 03:39 PM
405HP_Z06's Avatar
Aviaid offers complete bolt-in kits in many stages for this. They aren't a sponsor so you will have to Google them.
Old Jul 31, 2007 | 06:45 PM
gnx7's Avatar
You only need this if you are road racing with a car that pulls high g's. It will as mentioned cost some serious $$$'s.
A much cheaper solution is to run an Accusump system.
Most just run 7 quarts of oil in the Fbody pan so solve any oil pickup starvation problems.
Old Aug 1, 2007 | 07:31 PM
what is this?
Accusump system.
Old Aug 1, 2007 | 08:00 PM
Kamin's Avatar
accusump is the poor man's dry sump!
its an oil accumulator. basically the engine oil pump pressurizes a large cylinder with oil, then once its full it bypasses the cylinder and fills the engine normally. if there is a hiccup in oil delivery from the pump, to the engine, the accusump uses its "stored" oil to keep pressure in the engine.
dry sumps and accusumps are for road racing, they are completely pointless on a street car. why do you want one so bad?
Old Aug 16, 2007 | 09:26 PM
truely the reason be hind it.
well there are a few
First i have a dry sump motor. plan and simple
second help with pvc system on heads
third strait forward on oiling turbos
well those are the main ones.
oh that the famous line
to see if i can do it
Old Aug 18, 2007 | 12:34 PM
Snyper's Avatar
Not exactly sure why everyone needs to know WHY he wants it..the fact is he wants it..its his money...let him do what he wants with it...just give him the facts.
Old Aug 18, 2007 | 12:41 PM
Kamin's Avatar
yea but a true dry sump costs thousands of dollars. so if he doesnt need it, why waste the money? most people cant really say they have thousands of dollars to waste. if they do, i take donations for tires
Old Aug 18, 2007 | 01:20 PM
405HP_Z06's Avatar
Agree, point him in the correct direction and let him decide if it's right for him. If you haven't already, take a look at aviaid dot com.
Old Aug 19, 2007 | 09:56 PM
thatnk you guys that support the lead me in the right direction thing. ok.
wow
lots of money no joke.
so if the ls7 is not a true dry sump. then what kind of dry sump is it?
Old Aug 26, 2007 | 11:08 PM
GIGAPUNK's Avatar
The main differences between your standard dry sump and the LS7 system is that the LS7 sytem does not use external, belt driven pumps, and does generate significant crankcase vacuum.
Old Aug 28, 2007 | 02:52 PM
GR33N GoblinM6's Avatar
call up Jason at Katech Engineering... if you have "lots of money", Katech is the only company i would be talking to. They build the C6R motor's, and tons of road racing motors for other companies.
