Confirm cam checklist for me.
Old Aug 6, 2007 | 10:49 AM
blue98Z's Avatar
Default Confirm cam checklist for me.
Going cam only here in the next few weeks and for some reason I feel like I'm forgeting something. This is what I'm fixing to order:
-MS3 w/ spring and pushrod package
-Timing chain and ported oil pump package
-cam swap gasket kit
-SLP underdrive pulley
-rod bolts since I have a 2000 LS1
I know these are pretty much mandatory, but I feel like I'm forgeting something. Let me know if I am. Thanks.
Old Aug 6, 2007 | 10:51 AM
jomomma's Avatar
why the rod bolts?
Old Aug 6, 2007 | 11:18 AM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
he is prob gonna be taking it past 6500rpm's..... umm might want to consider new oil pan gasket just for safe measure and new pick up tube o ring
Old Aug 6, 2007 | 02:47 PM
blue98Z's Avatar
Yep your right on the 6500rpms. The oil pan leaks a little so I already was gonna do the pan gasket along with o-ring since I gotta take it off to do the rod bolts anyway. Other than that the list looks good?
Old Aug 6, 2007 | 02:56 PM
blue98Z's Avatar
fuel pump and injectors should be good for cam only huh?
Old Aug 6, 2007 | 03:02 PM
NOBR8KSS's Avatar
You should be fine with the fuel injectors...even if you're not, the PCM tuning will reveal that...no need to spend the $$ until you have to.
JC
Old Aug 6, 2007 | 09:56 PM
blue98Z's Avatar
I'll just have to see. Thanks. Josh.
Old Aug 7, 2007 | 07:33 AM
Ws6man2000's Avatar
i would go ahead and do the fuel pump and injectors if you have the money.....time saved if you get it out of the way no
Old Aug 7, 2007 | 08:11 AM
shooter's Avatar
I just did heads and cam put a set of SVO's 30 lbs, and my duty cycle was good to go on a stock pump, It's pumped up 441 rwhp.
Old Aug 7, 2007 | 08:15 AM
Ws6man2000's Avatar
hey shooter whats your torque numbers looking like? and what head gaskets are you running
Old Aug 7, 2007 | 12:03 PM
shooter's Avatar
torque numbers were 398, head gasket was 0.40 i'm pretty sure.
Old Aug 7, 2007 | 12:08 PM
Ws6man2000's Avatar
not bad sorry for stealing the thread and i appreciate it
Old Aug 7, 2007 | 04:28 PM
blue98Z's Avatar
will probably do them together. Since I'm putting a 9" in also it will be easy to drop the tank.
Old Aug 7, 2007 | 04:58 PM
snake charmer's Avatar
you might need some bandaids , a 12 pack of your favortie beverage and being your here in the south dont get too hot . also a friend can come in handy for the radiator and some moral support .
the injectors will be running on the high end of the duty cycle but they should be ok unless you are going to spray .
Old Aug 7, 2007 | 11:31 PM
blue98Z's Avatar
Not planning on the spray. Any suggestions on what to get as far as injectors. I do plan on doing heads later so I know I'll need the 255 pump with them, but if I upgrade injectors I only want to do it once.
Old Aug 8, 2007 | 02:59 AM
Ws6man2000's Avatar
i went with the svo 30lb injectors.... the guys at speed inc told me they flow at 36lbs or so on an ls1 fuel system. You can even search on here and i am sure there has been a topic or two about them and their flow rates
Old Aug 8, 2007 | 09:31 AM
RAACCR's Avatar
Pin the balancer to the crank while you've got it apart. You'll also need a new tty balancer bolt (unless you've got an aftermarket bolt like ARP). And, get a longer bolt to get the balancer started when you reinstall it.
Old Aug 8, 2007 | 06:23 PM
blue98Z's Avatar
Well looks like I'm ready to go. Just got to buy all the parts and get started. To snake charmer I just installed A/C and Heat into my shop so the southern heat is beat.
