TEA 5.3L heads are here, flow #'s inside
Jason
So I gathered that the bolts don't go down that far which leads me to believe that the silicone won't make it that far, right? Because if it did wouldn't the silicone seep out of the holes and cause more turbulence and/or problems?
So if the bolts don't reach that far down why don't the head porters fill it up to where the holes occur with some sort of epoxy or what ever before they port the heads? This way they can achieve a nice smooth port with no holes.
-The silicone isn't to plug the hole, the silicone is to seal the threads and keep intake port vacuum from sucking oil from the valvetrain side of the head down the threads and into the intake charge.
-The problem with epoxy is, no head porter is going to gamble on how much fill to use when he has no idea what manufacturer's bolt, for whatever valvetrain you decide to use, will thread into the hole. Furthermore, I don't know offhand of any epoxy that is designed to live it's whole life saturated with a petro-chemical like gasoline.
Be reaslistic about this.. there are hundreds and hundreds of ported heads out there... Just because this is the first you've heard of the issue doesn't make it a reason to push the panic button.
Those are some mad exhaust flow numbers! I don't want to doubt what TEA is saying, but dayum! My heads flowed a peak of 205.4, and I still managed over 400 RWHP in my setup.
I would be interested to see the numbers of those heads on an independent bench.
you can't get away from having holes there. The hole is only at the bottom of the rocker stud. Have you never seen a set of ported heads before? Almost every head I have ever seen that is ported well has this. Some are worse than other's it just depends on where the rocker bolt is located.
If you seen any professionally ported heads you will find these defects.The quest for power is crazy and trust me as a head porter with a sign in front of his shop and not a garage door that if you are trying to make serius power over 600hp you will have to weld up the spring perches and remachine the pads flat due to the fact that the roof has been raised .250, so the bolt stud means nothing. put it in and run until the bottle catches you
ill say again, TEA use's a pipe to flow there exhaust. Thats why there exhaust is higher than everyone elses by +10 - +20ish
steve
I agree 100%,those exhaust numbers are hard to swallow.Before I bought my 5.3 heads,I called all of the sponsor head porters.Tea is the only company with these high numbers(on the exhaust).Everyon else told me their heads flowed the same as the 5.7,that I could would only gain compression.When I ask them about the advertised high exhuast flow numbers,everyone told me "our research does not show it".I would love to also see a set of TEA 5.3 on a independent bench(superflow 1020).The TEA heads perform well,but I would like to see some posted flow numbers by someone other than TEA.
The use a pipe cause they want there numbers to show how it will perform on the car in live life sorta. If GTP and others used a pipe there exhaust flows would be about the same. There is no way heads can flow 260+ without a PIPE... its common sense people
I would love to see GTP flow numbers also, but those must be confidential for some odd reason. All those MTI/GTP cars out there, but when you do a search you only see TEA, AS, and some patriot flow numbers now
but once again... TEA USES A PIPE FOR THERE EXHAUST
The dont DENY that either I saw a post a while ago where someone had their brand new TEA 5.3's flowed on a independant bench. The intake numbers were 303CFM compared to 300CFM that showed on his flow sheet from TEA.
