TEA 5.3L heads are here, flow #'s inside
Either change to a reverse split or you may not be 100% happy with the cam from day one.
Either:
230 224 or 234/228 something like that
Phillip
GTP stage 2 flow numbers - 5.3l heads
These were flowed in house on a Super Flow 1020 bench. The bench is ~10-15cfm lower than GTPs bench.
I have personally flowed quite a few sets of TEAs and they were around 280cfm @ .550 on the intake and ~215cfm @.700 on the exhaust. They are excellent heads for the money.
Just because a head "A" flows more than head "B" doesn't mean "A" will make more horsepower than "B" on the dyno. I have seen this countless times on the bench. Flowbenches are excellent tools, but it's not the ultimate authority in determing how a head will do on a particular motor.
Jason
Did the tea heads port stall after .550? it used to be common.They are now using a diferent valve job that doesn't port stall.I will post my numbers when I get my new heads back. I will also have them flowed here in Chattanooga for a comparison.
The credit goes to a very smart man outta texas
Phillip
when it flows the same at higher lifts you go it is at max flow. So when he says it stalled at .500 lift he is saying it reached max flow. (max flow of the intake no doubt.) But I doubt it lost cfm after .500
I've not seen others test their parts to the same degree. It's hard to really draw conclusions without have the same set of data for all the other heads out there.
Intake GTP LS1
235CC
Intake GTP Stage II LS1
.050 - -
.100 65.8
.150 - -
.200 135.9 166.2
.250 - -
.300 200.8 224.8
.350 - -
.400 244.1 270.7
.450 - 288.9
.500 278.3 301.3
.525 - 304.7
.550 291.5 -
.575 - -
.600 285 -
.625 - -
.650 291.4 -
.700 - -
Exhaust
.050 - -
.100 51 -
.150 - -
.200 103.8 -
.250 - -
.300 141.5 -
.350 - -
.400 176.2 -
.450 - -
.500 190.4 -
.525 - -
.550 194.1 -
.575 - -
.600 198.3 -
.625 - -
.650 202.7 -
.700 - -
Here is a set of MTI LS6 stage 2 head (2.055/1.60) setup for a 3.90" bore. These were done on an independent bench. So, there isn't any magic going on here. Judge for yourself...
J-Rod, that's great info!
