The difference Torquer V.2 vs. Torquer V.3
Old Aug 8, 2007 | 05:40 PM
02 T/A 984's Avatar
Default The difference Torquer V.2 vs. Torquer V.3
ok just curious what is the performance difference between these two cams i know there's a difference in lift and everything but just curious on how the differ in performance
Old Aug 8, 2007 | 05:48 PM
Thorny's Avatar
I am also interested in this. The V.2 has an 1800-6400 advertised powerband while the V.3 has 2300-6700 powerband. I would think that since the LSA of the V.3 is lower that the powerband would be similar since the duration is almost the same. Does the change in intake lift really make that much of a difference.
I'm looking at either the torquer or 228R for a winter project, input would be great.
Old Aug 8, 2007 | 08:50 PM
CodeName Z06's Avatar
I am also interested to see what the different intake lobes really add in the performance area.
Old Aug 8, 2007 | 08:55 PM
blksheep's Avatar
find some graphs of the v2 and the v3 and compare...
Old Aug 9, 2007 | 06:26 AM
Fb0dy0nly's Avatar
call or PM TSP, they will give you all the info you want/need.
Old Aug 10, 2007 | 10:51 PM
'02 WS6's Avatar
my cam only torquer 2 graph is in the cam only dyno thread.
Old Aug 10, 2007 | 11:34 PM
MVDCGTO's Avatar
TSP says the V3 is good for 10-15rwhp, I think, over the V2 and better midrange. PS if you want a V3 I have one in the for sale section.
Old Aug 11, 2007 | 01:15 AM
pHEnomIC's Avatar
v2 kicks ***, v3 kicks a lot of ***
There are more factors to the cam other than lift and duration.
The v3 has the lsk intake lobes which are supposed to have very aggressive valve events.
Old Aug 11, 2007 | 11:06 AM
So i am guessing that the aggressive ramp rate on the lsk would givwe you the better mid range, due to higher lift sooner?
