Help me build my motor...
Going to be a carbed ls1 with a plate in a fox body.
Heads are ported 98 heads milled 35 thousandths with a valve/port job blah blah flow 300+ at 600 etc etc
stock ls1 block and stock crank will be used.
what rods and pistons would you all go with (forged etc).
Cam will be ground to match the heads and intake after I get the intake done by the guy who did the heads.
What plate would you run (or other nitrous kit) and any other suggestions on what you all might do.
I figure it should make around mid 4's on motor and dump 200 + of sauce on top of it if need be.
Tranny will be either th 400 or glide...leaning toward glide for longterm growth as thinking about possibly backhalving the car eventually.
AJ
AJ
I was just curious as to what rods people prefer to go with, and maybe just an off the shelf piston.
I looked i nthe P's really quick and could not find them as a sponsor.
