Cam install, how long????
Old Jun 1, 2003 | 09:17 AM
DEEZ98Z's Avatar
Default Cam install, how long????
I was wondering what the average time for a cam install is. I will already have the exhaust
manifolds off (puting Jethot Lt's on ) I will have full acess to a full line of tools... to include a
lift and A/C recovery system I am pretty mechanically incline, but this will be my first LS1
install. If you could post your times that would be good
Thanks
Wes
Old Jun 1, 2003 | 01:28 PM
2001CamaroGuy's Avatar
Default Re: Cam install, how long????
2 days if everything goes well (no problems). Most people get it done in a weekend (start Friday night finish Sunday some time.
Chris
Old Jun 1, 2003 | 02:59 PM
WillWorkForMods's Avatar
for the first time, assuming you have done similar work and maybe have a helping hand for a few things.... i'd say 5 hrs for the cam, 3 hrs for springs and putting the valve train back together
Old Jun 1, 2003 | 03:17 PM
White98LS1's Avatar
If u have any questions feel free to call me at 254 899 1049 i could walk u through it. Me and my helper have been averaging 4or less hrs, depending on how much bullshitting we do per cam swap thats with swaping springs and we use no air.
thanks
JJ
Old Jun 1, 2003 | 03:58 PM
99 TA's Avatar
It took a buddy and me 7 hours start to finish for headers, cam, springs, etc. I wish we would have had a lift. Save time not having to jack the car up.
Old Jun 1, 2003 | 04:43 PM
DEEZ98Z's Avatar
Hey thanks JJ.... I might just take you up on that I have 3 days (24hrs)
available in the shop, and I will be putting in a Vig 3600 at the same time So I should
have plenty of time as long as nothing goes wrong Keep them coming
Old Jun 1, 2003 | 06:49 PM
Brains's Avatar
A4's take a little longer than M6's, because you can't cheat on the balancer bolt Overall, a cam swap takes me 3-4 hours doing it by myself, and 4-5 hours if I'm walking someone else through it.
There's no need to drain the AC system, just lift the condenser and lower it out of your way..
Old Jun 1, 2003 | 08:49 PM
DEEZ98Z's Avatar
Thanks.... TTT
Old Jun 1, 2003 | 10:48 PM
wsix man's Avatar
it took a mechanic 15 hors to do my heads and cam. I just put the stock cam back in and it took me about 7 hours start to when I broke a rocker bolt in the block if it didnt break maybe an hour more and im not very mechanical either
Old Jun 2, 2003 | 08:08 PM
DEEZ98Z's Avatar
TTT
Old Jun 3, 2003 | 09:47 AM
Cal's Avatar
Cal
to include a
lift and A/C recovery system Wes
You don't have to unhook the A/C system.
Old Jun 3, 2003 | 11:22 AM
Constrictor 98TA's Avatar
Just a heads cam swap, it can definitely be done in one day. Now, for a heads/cam swap, that takes considerably longer!
Old Jun 3, 2003 | 05:02 PM
bigSS's Avatar
7.5 hours for my install.
Only like 2.5 hours for the actual cam swap, the rest for those damn REV springs!
Old Jun 3, 2003 | 05:13 PM
Assassin's Avatar
sweet damn, I've spent a day just cleaning the deck, bolt holes, heads, ect.. are you guys very thorough or am I just a slow *** bitch?
Old Jun 3, 2003 | 05:33 PM
Cal's Avatar
Cal
thanks
JJ
How do you swap springs without air to hold the valves up???
Old Jun 4, 2003 | 11:15 AM
DEEZ98Z's Avatar
thanks
JJ
You can do that by putting the piston at TDC... the valve will drop alittle but not much at all
Old Jun 4, 2003 | 12:19 PM
finalymodded's Avatar
dude I listened to these people and expected way less time than it really took. I did have to remove heads also to get out the lifters because I was changing them but, it took 2 full days the first time. The second time it took about 8 hours to break it down install and put it together. You will go very quick after you know where everything is but, first time takes a while. EVEN if you have instructions.
Old Jun 4, 2003 | 04:10 PM
da zman's Avatar
my first install took about 24 hours of work. you will NEVER have every part, so multiple trips to the store will commence. and if you think that those install guides tell you everything that you need to know then you are screwed the radiator is exciting.lol. and the valvesprings is a freakin NIGHTMARE. it will take a while to figure out how to "correctly" use the tool. i will never ever never do valvesprings again. screw that.
but overall it wasnt too bad. but you won't be doing it in 5-8 hrs.
mike
Old Jun 4, 2003 | 04:27 PM
importkilla's Avatar
What is a good resource for the average "Do it yourselfer"? I'll tell you what, I loved it when it came time to do some work on the 92 Silverado. Not a problem in sight. The LS1 on the other hand... jeeeeeze. I wouldn't mind getting my hands on a good reference manual for the LS1.
Old Jun 4, 2003 | 05:49 PM
Cal's Avatar
Cal
thanks
JJ
OK cool, that's how I'm gonna do it!
