Oil Consumption??????
Old Sep 17, 2007 | 09:12 PM
NHRArox's Avatar
Default Oil Consumption??????
how much oil consumption is ok for a car. right when im about to change my oil, at 3000 the low oil light comes on. so i put a quart in it and then change the oil in like a week???? is this too much or acceptable.....if its not acceptable, what can i do stop this.
Old Sep 17, 2007 | 09:18 PM
heavy6.0's Avatar
this might seem like a strange question but how long have you had the headers and off-road y-pipe?
Old Sep 17, 2007 | 09:25 PM
NHRArox's Avatar
ive had them probably 1 to 2 months tops......why?
Old Sep 18, 2007 | 03:10 PM
NHRArox's Avatar
bump....come on guys i need some help
Old Sep 18, 2007 | 03:37 PM
robertbartsch's Avatar
GM facotry engines are riddled with serious defects (Oil comsumption, bad oil pumps, exploding rockers, etc.)
Heavy oil consumption like yours is not normal.
GM should have recalled the LS1 engines but, unfortunately, it was not forced to do so by the Government.
Headers tend to make the situation worse. Try a HUGE oil catch can and hope for the best.
Old Sep 18, 2007 | 03:44 PM
Pharcyde50's Avatar
I'm running amsoil 5w30 and the updated pcv and no oil consumption here and my car us about to roll 100k.
Scott
Old Sep 18, 2007 | 04:07 PM
I have 56K on the clock and have never had ANY measurable oil consumption; my catch can is always dry as a bone!
Unfortunately, I am in the minority, however.
Old Sep 18, 2007 | 07:46 PM
Lt1Porsche's Avatar
I have 77K and i might lose 1/4 quart to 1/2 quart if anything. Most technicians will say that 1/2 quart is the average but if I am correct your low oil light comes on with 2.5 - 3.0 quarts missing. That is NOT NORMAL and should not be ignored. Good Luck.
Old Sep 18, 2007 | 07:50 PM
Brianss1's Avatar
what kind of oil do you use ?
Old Sep 20, 2007 | 03:28 PM
NHRArox's Avatar
i am using mobil 1 10w-30 and have been since i bought the car when it had 50k on it. now the car has 70k. why would the headers make it use more oil? sorry if this is a stupid question but i need to know what some possible diagnosises are and some ideas on what to do.
Old Sep 26, 2007 | 07:10 PM
Lt1Porsche's Avatar
I would switch the oil to a more conventional oil non synthetic for one cycle. Then check your consumption. Also use a quart of Lucas Oil Stabilizer then top off with oil. I bet your consumption problem will stop. And there is no harm in using conventional oil. Try Castrol 10w30.
