stock sounding CAM question!!!!
Old Sep 25, 2007 | 09:26 PM
hnaskoct's Avatar
Default stock sounding CAM question!!!!
is it possible to have a cam thats sounds identical to a stock ls1 cam because i have yet to hear it, and im thinking about going with the ls6 cam but i wanna make a little more power...can anyone help me because im not into the aggressive choppy lope im into the smooth stock idle sound are if anyone knows any links where i can hear what i want send it to me
Old Sep 25, 2007 | 10:01 PM
fatjet00's Avatar
It depends, I assume that you have a LT1 instead of an LS1. Also the earlier Ls1's had smaller cams in them. I own a 00 Z28, all stock except K&N FIPK. The cam in it is duration @ .050 intake 198 exhaust 209. Valve lift is .0500 on both intake and exhaust. On a 119.5 Lobe centerline. It's sounds good at idle. It's just a little choppy. Did you know there are 2 versions of the LS6 cam. Which one are you talking about? The 01, 385 horse power one or the 02-04, 405 horsepower cam. The later being a good bit bigger.
Old Sep 25, 2007 | 10:09 PM
hnaskoct's Avatar
i wasn thinking about going with the 03-04 zo6 cam and i have an 02 trans am but i dont know if the ls6 would make enough power like im looking for , i just want to make more power than stock and stioll have my stock sound.. b
Old Sep 25, 2007 | 10:13 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
LS6 will make good power, but it sounds like you need a cam that has about -15° of valve overlap. It will sound closer to stock that way. Have a custom cam ground. Call most of the sponsors, they can assist in the process if not do it for you.
Old Sep 25, 2007 | 10:24 PM
Websy21's Avatar
why are you so set with stock like sound, you will be leaving allot of power on the table you can still go fairly mild and have jsut barely noticable lope with more power than the LS6 cam will give you. Off topic, but if you got the money you could do this and heads and be laughing with gobs of power and stock like sound and driveabilty. It will jsut perform allot better
Old Sep 25, 2007 | 11:02 PM
Quick Double Nickel's Avatar
How about this cam spec from the mind of engineermike: 230/230 121-2. Should sound just like stock and get you all sorts of power. Oh, by the way, you'll have to spin it to 8,000rpm. No big problem, right.
By the way the LS7 cam is 210/230 120+4. It's got a little more lope than a stock LS1 though.
Old Sep 25, 2007 | 11:48 PM
hnaskoct's Avatar
i was also gonna do the 243 heads but i still need to know if there is cam that would sound like a stock ls1
Old Sep 26, 2007 | 12:12 AM
mvvette97's Avatar
check out the comp cam 54-424-11
http://www.tbyrne.com/ls1/ls1valvetrain.html
Old Sep 26, 2007 | 12:14 AM
00'WS6Rocket's Avatar
mti sells the stealth 1 and 2 cams those have a stock sound
Old Sep 26, 2007 | 02:44 AM
hnaskoct's Avatar
anyone can help with my question
Old Sep 26, 2007 | 04:14 AM
PREDATOR-Z's Avatar
LPE GT2-3 208/220
CheaTR cam 215/230
My custom grind
224/222 .609/.581 116+2 (I have it in my 370 and very close to stock through headers and custom Magnaflow catback)
MTI 224/220 .581/.581 116 (Stealth II)
Old Sep 26, 2007 | 07:35 AM
andrew69_04's Avatar
if you want it to sound stock y dont you just leave it stock? if you want more power then get what you pay for instead of just getting a portion of it.
Old Sep 26, 2007 | 07:49 AM
bjamick's Avatar
Yep your definitely going to have to have a wide LSA so you dont have much overlap. If you get an LS6 cam you will not even be able to tell that there is a cam in there it will sound like a vette pretty much.
So i guess to try and get the cam to sound stock but yet still get a nice performer. You have to have a high exhaust lift on the cam and a small intake and then a wide LSA? I believe thats how you get the stock sound although im no prredator or patrickG so im not to inclined on how to get a particular sound and what LSA you need and all that good stuff.
Old Sep 26, 2007 | 08:27 AM
davered00ss's Avatar
Moderator
That's what I was going to say. You are probably looking for something like a 220 0r 222 cam on a 114 or larger lsa.
Old Sep 26, 2007 | 09:56 AM
THE_PROFESSOR's Avatar
Try something with a 10* overlap if you are interested in more power with virtually no effect on low-end driveability. For a 40* intake closing angle (peak HP at 6000RPM) and a 50* exhaust opening at .050 (stock manifolds) try 216/224 XE lobe~.563 lift 115 +4.
For manifolds, shorten that to 40*/46*, 216/220 XE lobe ~563 114 +4. Both of these have a Dynamic Compression of a little less than 8.
just 10 min. of my time
Old Sep 26, 2007 | 10:52 AM
YankeeVert.'s Avatar
I have a 218/224 115 cam in my vert.It idles like stock (600 RPM) and makes plenty of power. The specs are in my sig. If stock sounding and driving is what you want this cam will do the trick.
