Ring Gapping LS1
Old Sep 25, 2007 | 10:20 PM
Sxyman815's Avatar
Default Ring Gapping LS1
Hey my block with rotating assymbly without heads takes 100 foot pounds to turn it over with torque wrench I didn't gap the oil rings and I think that is what it is do you have to gap the oil rings and what gap do I gap them at?
THANKS IN ADVANCE!!!!!!!!!
Old Sep 25, 2007 | 10:27 PM
machinistone's Avatar
You need to check your bearing clearances.
Old Sep 25, 2007 | 10:34 PM
Sxyman815's Avatar
not the bearings checked and double checked
Old Sep 25, 2007 | 10:47 PM
Sxyman815's Avatar
Do I need to gap the oil rings?
Old Sep 25, 2007 | 11:36 PM
Sxyman815's Avatar
Thumbs up
bump bump
Old Sep 26, 2007 | 01:07 AM
dmc454's Avatar
Default End gaps and bearing clearances
I would stop turning the motor over as you are damaging the crank.Take the rods off the crank and store these.Turn the crank over by hand.This should be only 20to30 pounds to rotate.If the turning torque is more take it back and explaine the situation to your machinist.Take the compretion rings off without damage check for flat rings.If any rings are not flat throw them away.to check for gap ring put the ring in the bore thes shoul be betrween .0017-0022..Fox the end gaps on the rings.once the crank comes back mount the crank back in the block.Turn with a torqe stick.this should only be 2-3 ft pds.
one you put the main caps on it scould only add 2-3 plds
Then add your pistons and rods.tis should be to 20 to 30 pounds.
If not and its higher somthing is bent.Hope this helps
Old Sep 26, 2007 | 02:01 AM
I have never had a set of oil rings that needed to be gapped.
If your clearances are correct, first before you remove the rods and pistons - loosen the center main caps and try to turn it again. If that makes a significant difference, your crank is most likely bent and you will need to put a dial indicator on there and measure the run-out. If loosening the mains makes no difference, do the process of elimination that dmc described. Start with just the crank and check torque to turn at each step of the process.
Old Sep 26, 2007 | 04:33 AM
BOWTIE's Avatar
Damn... first off, did you get all of the main caps back on the exact mains that they came off of, secondly do you have them all on in the right direction, do you have the thrust bearing in the right place? If so, before you tq the main bolts, give the crank a firm tap front to back, this will help align the thrust cap, then tq the mains. You should be able to easily turn the crank by hand. Also, did you get any of the rod caps mixed up or on backwards? If so, you are most likely screwed with the fractured rods. I also have never had to gap the oil rings, and i have used a couple sets of file fit rings, but the lower oil ring never needed anything. Good luck
Old Sep 26, 2007 | 08:52 PM
dmc454's Avatar
Default Sorry about advice
Sorry about the advice I gave .I looked at it just now .Drank some beer last night.Shouldn't advise while drinking.
