224/224 565/565 110lsa 106icl Comp Xe Dyno Graph.
Old Jun 4, 2003 | 05:10 PM
DailyAluminumBlock's Avatar
Default 224/224 565/565 110lsa 106icl Comp Xe Dyno Graph.
http://members.aol.com/blueflame6469/images/dyno2.jpg
Mods include ASP Pulley, Direct Flow Lid, FTRA, SLP Maf, Shaner S2 Tb, Hooker Long Tubes, LS6 Intake (car is an 01), Open hooker headers at the time with collector extensions, stock rear (now lanes 3" true duals with x pipe and flo pro twister muffs and 12 bolt with 4.11s), Zr1 17x11s in back, LS1 Edit SOTP tuning by me.
They didn't have a wide band so I don't know what my a/f ratio was but I can't be that off.
I really like the area under the curve of this cam with a stock short block that I don't want to spin more then 6400.
Old Jun 4, 2003 | 05:31 PM
niphilli's Avatar
Default Re: 224/224 565/565 110lsa 106icl Comp Xe Dyno Graph.
Nice results! Great torque and area under the curve. How are the driving characteristics? Bucking, surging? Where is idle set?
Old Jun 4, 2003 | 06:02 PM
The cam does not buck under 1200 rpm at all when warm, cold it acts stupid until about 1800 rpm. Even when I had 3.42s it lugged along just fine in 6th gear at 1400 rpms. I set my idle at 850 rpms.
Old Jun 4, 2003 | 06:07 PM
BADFNZ's Avatar
Shouldn't it peak a little higher than 6k?
Old Jun 4, 2003 | 06:14 PM
Not with a 106icl. The intake centerline, which controls the intake closing point, of a cam is probably the biggest determining factor in the rpm where peak power occurs in the ls1 when we are talking about cams with the same or similiar duration.
Old Jun 4, 2003 | 09:55 PM
DONAIMIAN's Avatar
Sound clip please
But tht is some nice tq you have. Most cam cars have like a a difference of 20 betwene the hp and tq
Old Jun 4, 2003 | 10:00 PM
When you are not spinning the motor to 7500+, tq is hard to beat for max accel. Track times will be soon to come as soon as we get some decen gosh D@mn weather.
Old Jun 5, 2003 | 04:30 AM
Larry's Avatar
Good thing you have a 12 bolt with that much low end torque. I bet you can pull some 60' times with this cam.
Did you have to fly cut the pistons? How much clearance did you have?
Old Jun 5, 2003 | 12:26 PM
Fenris Ulf's Avatar
Interesting. I would love to see if more intake duration with the same exhaust lobe would extend the topend power...
Old Jun 5, 2003 | 10:04 PM
Phil99TA's Avatar
Damn, I think that is the most torque I've ever seen in the 3000 rpm range on a non-stroked LS1 That is a badass cam! Is it a custom grind? You wouldn't have to rev that thing past 6200 rpms
Old Jun 6, 2003 | 12:26 AM
Bowtieman4life's Avatar
Are you running ported heads as well? I am looking for a cam set up as well and don't want to buy new heads.
Thanks
Old Jun 9, 2003 | 06:52 PM
dug's Avatar
dug
Those are some amazing numbers. Cam has moderate lift and duration and makes as much power and torque as the radical grinds. Also it does it at lower rpms. From the high torque numbers it looks like the cam timing is a perfect match with intake and long tubes.
Nicely done. I remember people were doubting because the large advance and narrow lsa.
Old Jun 9, 2003 | 08:33 PM
Damian's Avatar
LSX Mechanic
Damn! Makes me wish I kept my X1 with a 105 ICL
Josh
Old Jun 9, 2003 | 08:51 PM
CopMagnetLs1's Avatar
How's the idle?
Old Jun 10, 2003 | 12:29 AM
2000 ws6's Avatar
What is the part number or grind number for that cam? Did you install this cam dot to dot?
Old Jul 1, 2003 | 07:38 PM
BYBYC5's Avatar
*Bad Trader*
TTT any track times or any more info on this cam...
