what could this be????
Old Oct 4, 2007 | 07:13 PM
transamfreak01's Avatar
Default what could this be????
i threw 2 codes the other day.... they came up that in cylinder 1 was lean in bank 1 and bank 2. what could this be nd how can i fix it?
Old Oct 4, 2007 | 09:58 PM
8a8mfh's Avatar
Theres no such thing. It must have been sensor one bank one and sensor one bank two.
Thats means the front sensors are reading lean.
Old Oct 4, 2007 | 11:25 PM
well when i took it to autozone thats exactly what came up.... if its what u say than what can fix it?
Old Oct 5, 2007 | 01:26 AM
Azrael's Avatar
You need to get a wideband done to check your air fuel ratio. But it sounds like the codes were a lean condition detected by the PCM based a number of conditions. The codes were probably P0171 and P0174.
Check here: Gearchatter
Old Oct 5, 2007 | 01:42 AM
8a8mfh's Avatar
Take a look at your exhaust manifold, there is no way it can sense cylinder 1 being lean, they all merge together before the gasses hit the O2 sensor.
and how would it detect cylinder 1 lean in bank 2 when cylinder 1 is on the opposite side?
Old Oct 5, 2007 | 11:17 AM
now im about to install my wideband gauge would that be able to give me and idea or do u meen actually throw it on the dyno
Old Oct 6, 2007 | 02:36 PM
Old Oct 6, 2007 | 04:10 PM
SoCal01z28's Avatar
you still running the stock fuel pump? how many miles on the car?
