500 HP on 346. How can i get there???
My set up includes, an x3 cam, thunder racing pushrods, double springs, jet hot longtubes, and stock heads. My motor is in need of a rebuild and i'm trying to figure out what direction i can go in to get 500 flywheel hp out of the 346, if at allposible. Will an 11:1 bump in compresion and head work do the trick on my current setup? I'm kinda new to the LS1 world.
Thanks,
Harold
Port Pros LLC
512-257-0222
hey bro i have a 98 t/a bored 10 over compcams c/g 226/226 584 ona 112 asp under l/t pace 3400 daco stall 373 gears f/ram air ported t/b hp tuners best i could do is 12.6 @109 today i bought a whole 5.3 for 300$ dyno is 331 at the wheels and 312 tq what can be done to improve my ls1 with ls1 intake
Again in english?
What were the weather conditions for your run?
What was your 60ft?
What tires/traction/suspension mods?
What AFR and timing are you tuned to run?
What does the 5.3 have to do with it?
Need a lot more info for anyone to help out...
