Can you identify these lifters?
Old Oct 11, 2007 | 09:44 PM
sixthfloorfreak's Avatar
Default Can you identify these lifters?
Bought some used parts from a friend...heads, cam, etc...and I ended up with these lifters. Anybody know what they are? They're showing some wear unlike the stockers that were in my motor. Should I just reuse my stockers? Are these better?
Attached Thumbnails Can you identify these lifters?-camaro-074-resized.jpg   Can you identify these lifters?-camaro-075-resized.jpg
Old Oct 11, 2007 | 10:02 PM
blueeyeddevil141's Avatar
Some solid ****.
Old Oct 11, 2007 | 10:45 PM
Originally Posted by blueeyeddevil141
Some solid ****.
please forgive my ignorance, but what do you mean?
Old Oct 11, 2007 | 10:48 PM
They are not hydraulic, they are a solid roller lifter Has a solid valvetrain I assume.
Old Oct 11, 2007 | 10:50 PM
so do I not need to use these?
Old Oct 11, 2007 | 10:52 PM
Do you have a solid roller cam? Do you plan on spinning past 8,000 rpms?
Old Oct 11, 2007 | 11:10 PM
no sir...I'll be running them with the cam my friend was running them with...GM Hot Cam
Old Oct 11, 2007 | 11:24 PM
jegten's Avatar
i am not sure about this.
i just read your friend was running these lifters with the GM Hot Cam. are you sure?
did he know what car you are going to put this in?
i think we are fine with having all roller components.
the prior post asked if you have a solid roller cam. if your friend used these lifters with the cam, then maybe that cam is a solid roller cam. wouldn't you think?
i am just posting questions and thoughts i would have if i were you.
it seems you might be better off with a different package. just from what i have just read. JMHO.
careful with what you choose/get for your car, bro.
Old Oct 11, 2007 | 11:37 PM
Yea...somethings wrong. That is a small cam, and those are solid lifters(usually intended for a race motor, or very high reving motor)
Old Oct 11, 2007 | 11:47 PM
yeah, I'm all confused now. should I just go with the stockers I pulled out. buy a new set?
Old Oct 11, 2007 | 11:51 PM
Run stock lifters. The ones you have a pic of are NOT stock lifters.
Old Oct 15, 2007 | 01:28 AM
jegten's Avatar
make sure you have the right info on the cam.
