5g's for a build.. Opinions
Old Oct 16, 2007 | 05:39 PM
217zenki's Avatar
Default 5g's for a build.. Opinions
Im looking to rebuild my ls1 or take it another route.. Ive been looking around trying to figure out the best prices but havent came up with much..Im looking for the best bang for the buck.. Opinions please.. Note Ill be attempting to do all the labor myself.. Ive rebuilt a 350 ,318 and a 360 before so Im hoping this ls build wont be any tougher..
Old Oct 16, 2007 | 06:08 PM
theinstag8r's Avatar
I plan on doing heads/cam(Texas Speed) ,fast 90/90, and a 12 bolt (moser) for around 5g. hopefully should get me anywhere in the 450-500 at the wheels, then I'll probably be needing a clutch, doing all the work myself aside of the tune.
Old Oct 16, 2007 | 06:29 PM
217zenki's Avatar
Im looking to build the bottom end..
Old Oct 16, 2007 | 07:23 PM
bad6as's Avatar
the stock crank can hold a good bit over 700 i think, get some forged pistons and rods. what is it that you want to reaplce and what are you looking to do to the car
Old Oct 16, 2007 | 07:25 PM
DONAIMIAN's Avatar
Stock crank has held over 1000.
Old Oct 16, 2007 | 07:33 PM
heavymetals's Avatar
Why?
Does it need it?
Old Oct 16, 2007 | 08:13 PM
N4cer's Avatar
If you plan on big power it will. Might as well forge it now so you can use the parts that can be reused, instead of waiting on it to break and trash tons of stuff in the process.
Old Oct 16, 2007 | 08:21 PM
1999ssls1's Avatar
Forge it and spray the guts out of it. JMO
Old Oct 16, 2007 | 10:18 PM
transamfreak01's Avatar
yeah not to hi jack this thred but how much would it cost roughly to forge the motor say for nitrous
Old Oct 16, 2007 | 10:24 PM
217zenki's Avatar
Originally Posted by heavymetals
Why?
Does it need it?
I bought this car for 4g's the clock reads 160k but the seller claimed it was its 2nd engine with 80k on it.. The engine does have some stock# writing in yellow on it as if it was a junkyard engine.. But also when I first start it up it puts out a quick puff of slight white smoke..
Old Oct 16, 2007 | 10:25 PM
1999ssls1's Avatar
Just a good set off flat tops and prefferably some h beam rods. Roughly 1200 dollars for rods and pistons.
217zenki's Avatar
Some dd and to the strip.. I personally dont care about the comfortness of dd .. As long as it idles at a stop light Im ready to rock then.. I have other cars to drive daily..I want to replace majority of everything.. ls6 ported oilpump ,double roller timing chain ,headers,intake(not sure which fits in my budget?)clutch.. along thse lines.. Also i would try to buy as much used bolt ons from the classifieds here to save here and there..
Old Oct 16, 2007 | 10:27 PM
1999ssls1's Avatar
The white smoke is probably caused by oil in the intake. A catch can will solve that problem.
217zenki's Avatar
I was thinking about the vengenance vinidicator cam and the trick flow heads to go with it .. Forge the bottom and spray the hell out of it.. Sound good and doable for 5g's? Maybe not the Nitrous kit but everything else?
Old Oct 16, 2007 | 10:28 PM
217zenki's Avatar
Ive ran catch cans on previous turbo cars but whats the typical way for routing a catch can on the ls?
Old Oct 16, 2007 | 10:44 PM
Well, $5k to sink into the motor.
That's a tough one.
If you rebuild the motor (forge and whatever) and given that the crank isn't wornout or needs work you can make it go faster.
I would think almost $5k in parts without the spray though.
Old Oct 16, 2007 | 10:50 PM
N4cer's Avatar
I just did a 408 shortblock with good parts for under $4k.
Old Oct 16, 2007 | 11:11 PM
217zenki's Avatar
Really what kind of #'s r u making..
Old Oct 16, 2007 | 11:20 PM
N4cer's Avatar
Just got it back from the machine shop today. Still have to gap my rings and button it up. Then swap my parts over and install. I'm sure it's not gonna be a dyno queen, and I'm not a ricer, so dyno numbers won't matter. We'll see what kind of TIMES I run. With a 4L80e and a 9", the dyno won't tell the tale like the track will I'm sure.
Old Oct 16, 2007 | 11:26 PM
crazylane's Avatar
If you don't mind me asking, how did you do it under 4k??? Was it a salvage block or something?
Lane
