My cam versus the big boys MS4,MS3
#41
I drove it 10 miles after I installed it for the tune, so very little seat time untuned. All I remember is having to two-foot it and no lock-up on the highway. I wouldn't have wanted to drive it any further.
#43
to each his own, but i say big cam, big converter. i daily drove mine with a big cam of my design and a yank pye 4000... **** low end, mine never droped below 5400 when i put the hammer down...
#44
it takes more than a cam. It takes a great combo of every bolt on you can do along with a great tune.You have to match everything together. I have a little 224/228 581/588 cam with a 12 bolt that has 4.30 gears and a steel driveshaft and I out perform A LOT of the bigger cams. I put down 452 rwhp and 408rwtq. A small cam can kick *** but a well matched big cam combo can do even better. I just got done flycutting my pistons and I'm about to do the small vs. big cam shootout. If all goes well I should be at or very near 500rwhp. If I threw the stock rear and stock driveshaft back in it I would break the 500 mark for sure. I should be able to do it with the 12 bolt
#46
or am i wrong? anyways 452 whp is badass! maybe i will have to get a set of heads this winter....
#48
Every car will dyno different and every dyno will dyno different...**** the same dyno will dyno different every time....just cause they put down 450 some where else doenst mean they will put down 450 on every single dyno.
#49
Properly matched combo? lol what about the exceptions such as myself? J/k, i like my combo and it works. Like someone said in page one, a ms3/4 matched with a big stall and tire will do its magic. 11.72@115 cam only, MS3. thats on completely stock suspension also, stock crank pulley, stock TB, stock 853 heads obviously.
