spring seats breaking
Old Oct 19, 2007 | 03:15 PM
stevieturbo's Avatar
Default spring seats breaking
What would cause this ??? It has happened me on a couple of occasions now. The first one I spotted was worse than this though...so obviously like it longer ?
Once, Id have put down to a freak incident. But now 2 of them ? Whats going on ? Both times were on intake valves.
Springs are apparently Patriot Golds. Seat pressure is wrong, I can say that for sure, although Im trying to sort this now.
Given I tried contacting a few vendors here, and nobody actually seemed to want to sell me shims, or springs, or anything really to sort the seat pressure problem, and I do need it sorted urgently.
Ive had to resort to making some DIY shims, which will rest under the spring seat.
Why is it so difficult to buy stuff from some vendors ???? It baffles me. I say sell me springs, retainers, whatever, I dont care, just sell me the bits to correct my problem asap, and nobody even offers a solution.
Old Oct 19, 2007 | 03:37 PM
Yeahdoug's Avatar
Bad spring dynamics. Your valvetrain isn't happy. Set your springs up correctly and you should be fine.
It doesn't matter how good the parts are. If you don'tcorrect your install heights you're going to break morestuff.
With your springs install height .100" off, you only have about 100 lbs on the seat when you're supposed to have 140ish.
Old Oct 19, 2007 | 04:01 PM
xssive's Avatar
Ive got a full set of shims that you can have for really cheap!!!
PM me if you want them
Old Oct 19, 2007 | 04:47 PM
2xLS1's Avatar
How does the seat fit around the guide. Snug or sloppy. I think there are 2 different size spring seats (holes in center) available from Patriot depending of the size of the guide.
Old Oct 19, 2007 | 05:01 PM
vettenuts's Avatar
You can buy shims that go under the seats. They are Comp part numbers and come in 0.015, 0.030 and 0.060" or you can get a complete set with 16 of each thickness. The shims should be hardened, I wouldn't make them your self.
I agree, looks like you have severe spring dynamics issues, what is your setup?
Old Oct 19, 2007 | 05:52 PM
Head is as supplied Jan last year, and has done maybe 10-11k since. Its a CNC'd Edelbrock, with Patriot golds, Ti retainers etc. 0.581/0.591 cam, so nothing too mental.
Spring seat as pictured, is a very snug fit around the guide.
Installed height as I measured them, on about 3-4 valves anyway, is 1.86-1.87". I see no reason to believe the rest will be different. Worst case would be 1.89"
Ive been waiting on shims for about 2 weeks, only to be told on wednesday, they havent even been sent out yet But as I said, I have also tried to buy parts from others.....as I wanted to be sure Id have something on its way to me for this weekend.!!! which hasnt happened
So, as the picture shows, I have resorted to desperate measures, as one way or another, Im going racing next weekend, and my car will be running again this weekend.
I made them from 80thou thick Aluminum sheet... Now you say the shims need to be hardened. I ask why ?
The cylinder head is aluminum, and I will still be using the spring seat you see above ( except a new one....thankfully I got spares when I discovered the first one a few weeks ago )
So Im hoping placing my DIY Alu shims underneath the seat, wont cause any issues. A previous head I had, looked as if the shims and seat were made from copper !...by colour only. I didnt test it for hardness though.
Old Oct 19, 2007 | 06:30 PM
oz304's Avatar
are you runnind turbo?what brand of retainer are those?
Old Oct 19, 2007 | 06:37 PM
Im supercharged, that isnt the retainer, its the spring seat. The upper rpm has always been troublesome for me. But recently it has been pathetic. It barely wants to go over 6300rpm, although it will do it if you hold it. Hitting 7000rpm is but a dream at the minute though in the likes of 3rd and 4th.
Retainers are flat.
Old Oct 19, 2007 | 06:39 PM
Yeahdoug's Avatar
When you pulled the springs off your head, were the locks really hard to break free from the retainer?
Old Oct 19, 2007 | 07:21 PM
Tom@SpeedInc's Avatar
whos spring kit is that? retainers look like ones from AFR heads?
Old Oct 19, 2007 | 07:30 PM
pm sent
Old Oct 19, 2007 | 07:36 PM
2xLS1's Avatar
Yea, those don't look like the PP Super 7 locks and retainers. You might give those a try. They eliminate all movement around the valve groove. Clamp a pair of stock keepers around a valve and see how much you can move them up and down. Then do the same thing with the Super 7s. They won't move at all.
Old Oct 19, 2007 | 07:49 PM
oz304's Avatar
we are talking about the intake seats i assume? if your boosting more than the engine ve needs it put a counter shock load on the intake valves,where the comp exceeds the valve spring pressures especially at high rpm/boost loads to combat this its best to retard the timing a few degrees to allow more flow for the high rpms and less back pressure to the intakes valves at times when they try to open. why it used to rev better is because the springs could cope with demand back then,it wouldn't help if the boost got upped in the process as far as rpms are concerned,but heck it really wants to like a dog hit with a shovel,+ who could blame you.maybe the cam profile is a tad too aggressive for the amount of boost your running.higher duration,lazier profile rates
seem to promote less shock loads on the higher boosted engines.
copper shims are nice too.
Old Oct 19, 2007 | 07:56 PM
Yes, both broken spring seat incidents were on the intake valves.
As for locks and retainers. Breaking the seal to remove the collets, was a PITA. They are tight !!!!
How you guys manage this using only air to hold the valves shut, is beyond me.
I had to fill the cylinder with rope, and wind the piston up. Even then, it was a struggle on some of them.
Old Oct 19, 2007 | 08:10 PM
oz304's Avatar
arrrghhh!
lets just say they are locked real good!
usually a sharp quick blow with a 2lb hammer to each side of the retainer usually does the trick,but in your situation its kinda unusual with them springs,boost and revs.
by the way you could be doing mid 9s you must have traction issues no?
Old Oct 19, 2007 | 08:48 PM
2xLS1's Avatar
The locks to the retainers may be tight, but if those are stock locks, the locks to the valve grooves are sloppy loose.
Old Oct 19, 2007 | 08:57 PM
2xLS1's Avatar
Check out the movies at the bottom of this page. They are courtesy of Yeahdoug.
http://www.racingsprings.com/Pictures.htm
Old Oct 19, 2007 | 09:12 PM
tap the retainers few times with a small heavy headed rubber mallet (like the ones snap on sells full of BBs in the head), the valve locks will free up.
Old Oct 19, 2007 | 10:20 PM
Yeahdoug's Avatar
I brought that up because if they're really jammed on there it is just another sign of bad dynamics. You can usually judge how well a valvetrain is working together on how easy the locks break loose.
I agree that those retainers do not look like PP.
I'd say get a spring kit from someone and start over. If the dynamics are bad enough to break your seats, there's a good chance that the springs might have taken a set.
Also give the rest of your valvetrain a look over. Take a look at your pushrods.
Old Oct 20, 2007 | 12:31 PM
vettenuts's Avatar
Your installed height seems kind of high, I would have expected 1.760 or something like that. I have never seen them installed over 1.800".
As for the copper color on the shims, I believe that is just a coating on the steel shim, at least the ones I used.
Here are the part numbers if you need them. The first three sets are individual packs of 16 of one thickness, the set is 16 of each which may be more useful.
