How often do water pumps go??????
Old Oct 20, 2007 | 10:57 AM
smokeum99ta's Avatar
Default How often do water pumps go??????
I'm woring on a friends 99 ta and he told me that it is leaking antifreeze. I spotted the leak underneath the waterpump while the motor was running. This motor has never been gone into so I doubt the gaskets are bad plus it coming from under the pump not the sides where the gaskets are. The car has under 70k on it . Is that common for waterpumps to go soon?
Old Oct 20, 2007 | 11:30 AM
99blancoSS's Avatar
WP's are a funny animal. Some last forever and some fail prematurly., If its leaking it's bad.
Old Oct 20, 2007 | 11:31 AM
ls1ws9ta's Avatar
mine has 179k on a factory pump..... :crossfingers:
Old Oct 20, 2007 | 10:52 PM
jmilz28's Avatar
Coolant leaks in general are not common on LS engines. Water pump is most likely culprit and based on your explanation, sounds like it.
Secondly, this is not "soon." The car is 9+ years old. It's low mileage for what it is, but it is getting to be an old car, things will go wrong. My guess is, the coolant is original and never been flushed. You need to flush the coolant about every 2 years and your water pump will last MUCH longer.
Regardless, 9 years is a good life span for a water pump. Change the hoses while you are at it if you plan to keep this car. These cars are not sophisticated but the upside is, if you maintain them well, they will go for a long time.
Good luck!
Old Oct 21, 2007 | 03:01 AM
z28ss4me's Avatar
I had 120k on mine when the leak got bad enough for me to do something about it. I swapped out the gaskets and viola, no more leak! Worth a shot I guess if you're trying to save cash. I mean you'll need the gaskets regardless.
Old Oct 21, 2007 | 04:11 AM
brians98ss's Avatar
The waterpump on my 95 LT1 went bad at 65k miles, 01 Cavalier at 75k. Even though the original pump on my 98 was still good at 40k I replaced it when I had the motor out.
Old Oct 21, 2007 | 05:06 AM
01Z28M6's Avatar
I just replaced mine for the 01 at 66k miles. I had been smelling antifreeze for quite a while but never saw any leaks. I took the car to the track and noticed coolant splattered on the hood. Got the car up and finally spotted some drops hanging on the pump.
Old Oct 21, 2007 | 06:07 AM
trans_am_31's Avatar
My wp lasted for over 180 k. It just went out about a month ago. IF its not leaking at the gaskets, then its leaking through the weep hole. Good luck
Old Oct 21, 2007 | 10:40 AM
bmax's Avatar
Mine went out around 120,000 miles. Easy to replace.
Old Oct 21, 2007 | 01:14 PM
mullenh's Avatar
1. the pump is around 8 years old.
2. how often (if ever) did he change the coolant?
3. lot of city miles too i'll bet.
Old Oct 21, 2007 | 01:42 PM
GMTECH4's Avatar
mine is a 98 with 130mi and my water pump just went out about a week ago
Old Oct 21, 2007 | 02:48 PM
Jimmard's Avatar
well mine is an 02 and it went bad with 35k on the clock, fairly easy to replace
Old May 14, 2008 | 09:46 PM
95TAJade's Avatar
how "easy" is easy? I found this nice puddle of coolant under my car today after I got to work.
Old May 14, 2008 | 11:02 PM
SOMbitch's Avatar
Yep. Gaskets rarely go bad but the weep hole indicates the bearing seal is bad and replacement is imminent.
Old May 14, 2008 | 11:11 PM
N/Apower's Avatar
Mine died at 76K. Yes, it is pretty dang easy to replace. I watched it done as I had never been under the hood with a wrench on one of these before. Cost me $100 for that and the window motor replacement labor. Good to know ppl.
Old May 15, 2008 | 12:47 AM
ultraz's Avatar
uh oh, ive got a 98 thats going to 130k this week....... Crossed fingers, LOL. Mine has a very Minor leak through the weep hole.
Old May 15, 2008 | 12:50 AM
99problemz's Avatar
mine went out around 90k
Old May 15, 2008 | 07:45 AM
TS99V6's Avatar
Mine went out at 25k miles.
Old May 15, 2008 | 07:48 AM
BTLD_LS1's Avatar
mine went over 200K, then got a replacement from napa that died after 2500 miles....
