dumb questions from an LSx dummy
Old Oct 26, 2007 | 06:15 PM
fireman's Avatar
Default dumb questions from an LSx dummy
I know zero about LS motors but have a couple questions.
What I would like is a 4.8L with an aluminum block. Will a 4.8l Vortec rotating assembly just drop right in an LS1 block? I know the bore on a 4.8l and 5.3l is 96.01mm, is the standard LS1 bore the same?
Thank you.
Old Oct 26, 2007 | 06:26 PM
socmguy's Avatar
Restricted User
not sure about that, but why the hell would you want to put that in an LS1 block. It's built by the hands of God!!!
Old Oct 26, 2007 | 06:32 PM
BlackLS199's Avatar
what he said lol
Old Oct 26, 2007 | 06:33 PM
red_ryderSS's Avatar
Why change ur internals? Did you break something? I'm guessing high mileage, spun bearing. Just go forged pistons, crank and rods and enjoy.
Old Oct 26, 2007 | 06:48 PM
fireman's Avatar
I have a cam only LT1 right now that runs just fine.
I would like an all aluminum 4.8 LS based motor and am looking for the easiest way to do this. I thought an LS1 block may be my best choice, but I don't know if it will accept the 4.8 stuff.
Old Oct 26, 2007 | 06:54 PM
Phoenix 5.7's Avatar
why 4.8? what is the point of the baby motor?
Old Oct 26, 2007 | 07:06 PM
fireman's Avatar
Its what I want
Old Oct 26, 2007 | 09:09 PM
tilly's Avatar
Yea, be more descriptive on why you want a 4.8. The LS1 has been around for a lot longer and would easier to find parts for. I'm quite on curious for why the 4.8.
Old Oct 26, 2007 | 09:23 PM
fireman's Avatar
Okay---
Picture 2 engine stands.
Stand on left has factory stock 4.8l Vortec shortblock assembly, stand on right has factory stock, bare 5.7 LS1 aluminum block.
Can I remove the crank, rods, and pistons from the 4.8l and install them onto the LS1 block. Will it fit? Will it work?
This is what I'm asking, I'm not real sure how much more descriptive I can be.
Old Oct 26, 2007 | 09:56 PM
2xLS1's Avatar
No the LS1 has a bore size of 99mm (3.8976 -in.).
Old Oct 26, 2007 | 10:39 PM
fireman's Avatar
Thank you,thats what I wanted to know.
Old Oct 26, 2007 | 10:43 PM
Soul TKR's Avatar
this thread is funny... glad you found your answer though
